Is Multiplying Phase Readings a Valid Method to Verify Transformer Load Balance?
The discussion centers on verifying transformer load balance through the analysis of low-voltage (LV) side ampere readings. The method proposed involves multiplying the readings from phases R, S, and T to confirm their accuracy and assess neutral current. However, it is established that neutral current consists of both unbalanced load and third harmonic current, necessitating the use of a spectrum analyzer to differentiate between these components. This approach ensures a more accurate evaluation of load distribution and neutral current measurement.
  • Understanding of transformer load balance concepts
  • Knowledge of electrical phase relationships (120-degree phase difference)
  • Familiarity with neutral current characteristics
  • Experience with spectrum analyzers for electrical measurements
  • Research methods for analyzing neutral current using a spectrum analyzer
  • Learn about the impact of third harmonic current on neutral measurements
  • Investigate techniques for load balancing in electrical systems
  • Explore the principles of power factor correction in electrical devices
Electrical engineers, technicians working with transformers, and professionals involved in load balancing and electrical measurements will benefit from this discussion.
Muhammad Saber
I'm working in electrical company in a department in which I receive transformer LV side ampere readings and in most of these readings the neutral has amperege due to unbalanced loading, all I need a method in which I be certain that these readings are actual measured values specially neutral measuremen to make reldistributing the load to the phases, I thought that when I multiply the r,s,t readings the phase between r,s,t which is 120 diffrence it will make me be sure that these phases reading are correct and the neutral amperege. Is that right , if not what is the way to investigate these readings.
i cannot make sense of that sentence.
What are you multiplying by what ? and why ?
Neutral current includes both unbalance AND third harmonic current.
Electronic devices made before power factor correction was mandated draw a lot of third harmonic current that shows up in the neutral. .
You'll need to look at your neutral current with a spectrum analyzer to know how much of it is at line frequency(unbalance) and how much is at 3X line frequency(electronic loads).
  • · Replies 16 ·
35K
