Ampere's Circuital Law: E Field Constant ∫H⋅dl
  • Context: Graduate
  • Thread starter Thread starter mairzydoats
    Law
The discussion revolves around the implications of Ampere's Circuital Law in the context of a constant electric field and a shrinking loop. Participants explore whether a non-zero line integral of the magnetic field (∫H⋅dl) can be induced around the loop despite the absence of a magnetic field and current, focusing on the relationship between electric flux and induced electromotive force (EMF).
  • Exploratory, Technical explanation, Debate/contested
  • One participant proposes a scenario with a constant electric field and a shrinking loop, questioning if ∫H⋅dl would be non-zero as the loop shrinks.
  • Another participant suggests that the line integral should be zero since the magnetic field H is zero everywhere.
  • A different viewpoint introduces the concept of displacement current, likening the situation to Faraday's law and discussing potential EMF induced by changing contours of the loop.
  • One participant emphasizes the importance of Maxwell's equations and the implications of moving surfaces and boundary curves on the electric flux and induced fields.
  • Another participant expresses skepticism about the physical relevance of the shrinking loop, questioning whether it could influence any fields.
  • One participant argues that the scenario should be analyzed in terms of compass deflection along the loop's perimeter, suggesting that a magnetic field could still affect compass readings.
  • Another participant examines the mathematical consistency of the assumptions made, concluding that no magnetic field is induced in the lab frame.
  • A later reply questions how the deflection of a compass in a local rest frame could be reconciled with the absence of a magnetic field in the lab frame.
  • One participant clarifies that the original scenario does not involve moving a compass in an electric field, which complicates the analysis.
Participants express differing views on whether a magnetic field can be induced in the described scenario. Some argue that no magnetic field is generated, while others suggest that the effects on compass deflection indicate a more complex interaction. The discussion remains unresolved with multiple competing perspectives.
Participants note limitations in the assumptions made, particularly regarding the physical relevance of the shrinking loop and the implications of the local rest frame versus the lab frame. There are also unresolved mathematical steps in the application of Maxwell's equations.
mairzydoats
Imagine an E field coming out of your screen that is constant everywhere in space and time (∂E/∂t=0). And in your reference frame, let's say that this the only field there is -- there is no B.
Say there is a loop in the plane of your screen, and so the plane of this loop is perpendicular to the E. If the loop starts shrinking, will there be any non-zero value of ∫H⋅dl induced around it as it shrinks?
There is no current through the the loop, and E is constant inside of it.
Perhaps I misunderstand the question, but how should this line integral not simply be just 0, because ##\vec{H}=\vec{B}/\mu=0## everywhere?
The amount of E passing through a surface enclosed by the shrinking loop is lessening even though E itself is time-constant inside of it. Would that be like a displacement current through it?
After all, in a Faraday law analogy, if it were a loop perpendicular to a B field, there would be 2 ways EMF could be induced in the loop:
1) The contours of the loop remaining fixed, but B varying with time - transformer EMF
2) B being time constant, but the contours of the loop changing - motional EMF
or some combination of both.
Isn't there some magnetic field analogy to EMF that would make moving the contours of the loop have the same displacement-current effects on it as holding the contours fixed and varying E through the bounded surface of it?
That's indeed an interesting question. It has to do with the correct form of the Maxwell equations in integral form when moving surfaces and boundary curves are involved.
First we note that for an arbitrary vector field ##\vec{V}(t,\vec{x})## and an area ##F## with surface-normal vectors ##\mathrm{d} \vec{f}## one has
$$\frac{\mathrm{d}}{\mathrm{d} t} \int_F \mathrm{d} \vec{f} \cdot \vec{V}(t,\vec{x})=\int_F \mathrm{d} \vec{f} \cdot [\partial_t \vec{V}(t,\vec{x}) + \vec{v}(t,\vec{x})(\vec{\nabla} \cdot \vec{V}(t,\vec{x})]-\int_{\partial F} \mathrm{d} \vec{x} \cdot [\vec{v}(t,\vec{x})\times \vec{V}(t,\vec{x})].$$
For a proof, see
https://en.wikipedia.org/wiki/Leibniz_integral_rule
Now we apply this to the "electric flux"
$$\Phi_{\vec{E}}(t)=\int_F \mathrm{d} \vec{f} \cdot \vec{E}(t,\vec{x}).$$
Taking the time derivative gives according to the above mathematical theorem
$$\frac{\mathrm{d}}{\mathrm{d} t}=\int_F \mathrm{d} \vec{f} \cdot [\partial_t \vec{E}(t,\vec{x}) + \vec{v}(t,\vec{x})(\vec{\nabla} \cdot \vec{E}(t,\vec{x})]-\int_{\partial F} \mathrm{d} \vec{x} \cdot [\vec{v}(t,\vec{x})\times \vec{E}(t,\vec{x})].$$
Using the Ampere-Maxwell Law,
$$\vec{\nabla} \times \vec{B}-\frac{1}{c} \partial_t \vec{E}=\frac{1}{c} \vec{j},$$
and Gauss's Law,
$$\vec{\nabla} \cdot \vec{E}=\rho,$$
we find after using Stokes's theorem
$$\frac{1}{c} \frac{\mathrm{d}}{\mathrm{d} t} \Phi_{\vec{E}} =-\frac{1}{c} \int_F \mathrm{d} \vec{f} \cdot [\vec{j}-\rho \vec{v}] + \int_{\partial F} \mathrm{d} \vec{x} \cdot \left (\vec{B}-\frac{\vec{v}}{c} \times \vec{E} \right ).$$
is this a yes?
Hi,
It's obvious that the flux will decrease since the loop is shinking but I'm afraid this reduction will be compensated with the term - dx · (v/c x E) so that the magnetic field will not change.
In the link given by vanhees71, https://en.wikipedia.org/wiki/Leibniz_integral_rule, v is "the velocity of movement of the region", so when shinking a circular loop, v must go towards the center, so that v x E will be parallel to the direction of the line (dx).
Think that this loop without current (and I assume also with no charge) may be an imaginary artifact, so, how could it change any field?
Sergio
Not an imaginary artifact. We have to be able to determine, yes or no, if compasses situated along the perimeter of the shrinking loop in the constant E field would deflect. Either they would or they wouldn't.
I'm not so sure about this. Take the formula given above. In this case I guess we have ##\rho=0##, ##\vec{j}=0##, and ##\vec{B}=0##. Let's see whether this is consistent with the integral formula above (it's amazing that I couldn't find this straight-forward formula in any textbook, but unfortunately also the correct Faraday Law is rare in the literature; it's really strange, why nobody seems to address this in the more advanced books like Jackson, but of course the Faraday Law has important applications like the homopolar generator, while the analogous here discussed situation with the Ampere-Maxwell law seems to have not such applications).
Let's take the loop to be circular with a radius ##a(t)## in the ##xy##-plane of a Cartesian coordinate system and ##\vec{E}=E \vec{e}_3##, ##E=\text{const}##. Then it's convenient to use cylinder coordinates ##(x,y,z)=(\rho \cos \varphi,\rho \sin \varphi,z)##. The electric flux through the circle bounded by the loop is
$$\Phi_{\vec{E}}=\int_0^{a(t)} \mathrm{d} \rho \int_{0}^{2 \pi} \mathrm{d} \varphi \rho \vec{e}_3 \cdot \vec{E}=\pi a^2(t) E\; \Rightarrow \; \dot{\Phi}_{\vec{E}}=2 \pi a(t) \dot{a}(t) E.$$
For the velocity field along the loop is
$$\vec{v}(t,\vec{x})=\dot{a}(t) \vec{e}_{\rho},$$
and the line integral thus is
$$\int_{\partial F} \mathrm{d} \vec{x} \cdot \vec{v} \times \vec{E}=\int_0^{2 \pi} \mathrm{d} \varphi a(t) \vec{e}_{\varphi} \cdot \dot{a}(t) \vec{e}_{\rho} \times E \vec{e}_z = a(t) \dot{a}(t) E \int_0^{2 \pi} (-1)=-2 \pi a(t) \dot{a}(t).$$
So above assumptions are consistent with the integral formula for our case:
$$\dot{\Phi}_{\vec{E}}=-\int_{\partial F} \mathrm{d} \vec{x} \cdot (\vec{v} \times \vec{E}).$$
So it seems as if simply no magnetic field will be induced.
Let's also check qualitatively the force on the electrons in the wire. In the local rest frame of each wire element there is a magnetic field ##\vec{B}'=\propto \vec{v} \times \vec{E}=-\dot{a}(t) E \vec{e}_{\varphi}##. The Lorentz force on an electron thus is ##\propto \vec{v} \times \vec{B}' \propto \dot{a} E \vec{e}_{\rho} \times \vec{e}_{\varphi} \propto -\vec{e}_z##. So there's no current induced in the wire and thus also no B-field in the lab frame.
The conclusion is again that here no magnetic field is induced.
But if in the local rest frame of each wire element there is a magnetic field B-prime, then presumably a compass situated one of the elements and riding along with it would be accordingly deflected.
With no B-field in the lab frame, what is there in the body of electromagnetic law to account for this effect in the lab frame? Assuming, that is, that the compasses would also be deflected in the lab frame. After all, isn't a needle's deflection versus non-deflection kind of hard to "transform away"?
When you move a compas in an electric field, it will react to the magnetic field in its rest frame, but that's not the situation described un the OP.
  • · Replies 16 ·
