An apparently tricky problem on Friction/Forces.
  • Thread starter Thread starter cantgetaname
The problem involves two bodies of mass m1 and m2 on a horizontal table with a coefficient of friction μ, connected by a spring. The objective is to determine the minimum force F applied to m1 that will cause m2 to just begin to move, considering the effects of friction and the spring's force.
  • Mixed
  • Participants discuss the forces acting on both masses, particularly the role of the spring and friction. There are attempts to derive the expression for the applied force F, with some participants questioning the assumptions made regarding the spring's behavior and the forces involved.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have offered hints and insights regarding the energy considerations and the nature of the forces acting on the masses. There is no explicit consensus yet, as different approaches to the problem are still being examined.
Participants are navigating the complexities of the problem, including the need to account for the spring's elongation and the forces required to overcome friction. There are also discussions about the implications of applying a constant force versus a varying force.
cantgetaname
Two bodies of mass m1 and m2 are placed on a horizontal table with coefficient of friction \mu and are joined by a spring. Initially, the spring has its natural length.
If F is the minimum force which, when applied on m1, will make the other block m2 just move, find F. (k is the spring constant)
Here is an artistic illustration of the situation.
  1. Limiting Frictional Force = \mu x Normal/reaction offered by the surface.
  2. Force due to spring = k * Elongation of spring (from its natural length)
If m2 is to move, it needs to experience a force of \mu m_{2}g (to oppose the friction), which can be only experienced from the spring.
This means the spring's elongation at that instant is atleast \frac{\mu m_{2}g}{k}.
An equal and opposite force acts on m1. For m1 to move, net force on it must be greater than \mu m_{1}g.
That gives F=\mu m_{1}g+\mu m_{2}g, which is incorrect.
The answer is F=\mu m_{1}g+\frac{\mu m_{2}g}{2}, which I have no idea of where it could possibly come from.
Does the spring act only on m2?
Well, it obviously acts on both.
It can't possibly act on just one object.
That is precisely correct. F = -kx assumes that one end of the spring is fixed, which is not true in this case. Try a special coordinate system where one direction is toward the center of the spring, and one direction is away from the center of the spring.
So far, so good!
That's certainly true.
Hint: Realize that the applied force just has to be enough to get m1 moving and stretch the spring the right amount. Think in terms of energy.
Doc Al said:
So far, so good!
No, the problems asks the force which makes m2 just move. I do not see why the minimal force is not (m1+m2)g .
ehild
I assume you meant μ(m1+m2)g.
Ask yourself: If you applied such a force through a distance x (the required elongation), how much energy will m1 have? If m1 has extra energy beyond that needed to stretch the spring, then you've pushed too hard. Note that the spring force is not constant.
Sorry, i meant ug(m1+m2). Does the problem ask the minimum constant force? If so, it is really
ug(m1+m2/2), and anyway, it is less than ug(m1+m2), so you are right... :blushing:
So we apply a constant force F along a path Δx, first accelerating m1, than letting it decelerate, stopping at the end. According to the Work-Energy Theorem, the work of all forces equals to the change of KE which is zero now. So
W=(F-μm1g)Δx-kΔx2/2 =0, F=μm1g+kΔx/2
ehild
