An electron traveling at a speed of
  • Thread starter Thread starter atoreta88
    Electron Speed
An electron traveling at 6.0 x 10^7 m/s strikes an x-ray tube target, decelerating to 1/4th of its speed and emitting an x-ray. To find the wavelength of the x-ray photon, the kinetic energy of the electron should first be calculated using the formula K.E = 1/2 m*v^2. The correct approach involves using the relationship between energy and wavelength, specifically lambda = (h*v)/K.E. However, participants emphasize that it's important for the original poster to work through the problem independently rather than having their calculations done for them. The discussion highlights the need for proper dimensional analysis and understanding of the equations involved.
atoreta88
An electron traveling at a speed of 6.0 x10^7 m/s. strikes the target of an x-ray tube. Upon impact, the electron decelerates to 1/4th of its original speed, emitting an x-ray in the process. What is the wavelength of the x-ray photon?
I think I'm suppose to use the formula E=hf (eqn 1) and v=lambda*f (eqn 2)
I manipulated both equations (eqn 1 and eqn 2) to get the formula E=(h*v)/(lambda), but that leaves me with two unknowns..when all I want is lambda to be the only unknown. I'm not sure how I would find the energy...and I'm not sure if I'm even using the correct formulas. Hopefully I'm on the right track?
What you want is the wavelength of the X-ray - an EM wave. What is its speed ?
we can find the wavelength of the emitted x-ray photon. using
first find the kinetic energy of the electron using K.E = 1/2 m*v^2.
then apply the formula
lambda = (h*v)/K.E
it will give the answer for you.
lambda = (h*v)/K.E
That is incorrect. Even a dimensional analysis shows that there is something wrong with that equation.
And please do not do the original poster's (OP's) work for them -- they are required to do the work themselves. You may provide hints and ask questions, in order to help them figure out the problem on their own.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
