MHB What is the pattern behind the repeating decimal in this interesting fraction?
soroban
\displaystyle\frac{1}{998,001} \;=\;0.\overline{000\,001\,002\,003\,004\,005\, \cdots\,996\,997\,999}\, \cdots
The decimal representation contains all the 3-digit numbers except 998
. . and the 2997-digit cycle repeats forever.
This is just one of a family of such fractions.
Can you determine the underlying characteristic?
Mathematics news on Phys.org
The pattern must be that this is the third member of a series starting
$\dfrac1{81} = \dfrac1{9^2} = 0.\overline{012345679}$,
$\dfrac1{9801} = \dfrac1{99^2} = 0.\overline{00\,01\,02\,03\,04\,05\cdots 96\,97\,99}$,
$\dfrac1{998\,001} = \dfrac1{999^2} = 0.\overline{000\,001\,002\,003\,004\,005\cdots 996\,997\,999}$.
You can sort of see why this works if you consider the binomial series
$(1-x)^{-2} = 1+2x+3x^2+4x^3+5x^4+\ldots$,
with $x = 1/10^k$. For example, if $k=1$ you get
$$\begin{aligned}\tfrac1{81} = 9^{-2} = (10-1)^{-2} &= \tfrac1{100}\bigl(1-\tfrac1{10}\bigr)^{-2} \\ &= \tfrac1{100}\bigl(1 + \tfrac2{10} + \tfrac3{100} +\tfrac4{1000} + \ldots\bigr).\end{aligned}$$
That gives you $\frac1{81} = 0.01234...$. The trouble starts when you have to try to justify why the 8 gets left out, and why the decimal starts to recur after the 9.
may be that's because after 9/10^8 we have 10/10^9=1/10^8...that implies
9/10^8+1/10^8=10/10^8=1/10^7...
which transforms or (eliminates to reproduce) 8/10^7 into 9/10^7 and recurring i am working on that...:confused:
There is additional discussion http://www.mathhelpboards.com/f9/1-998001-a-3403/.
The answer, as it ends up, is simple. As you have hinted, we can write this as
$$\frac{1}{(10^n-1)^2}=\sum_{k=0}^{\infty}\frac{k}{10^{n(k+1)}}$$
To start, let's focus on the case of $\frac{1}{81}$, that is, the $n=1$ case. In this case, we have
1/81 =
.01 +
.002 +
.0003 + ...
which starts out fine. However, eventually we reach
...08 +
...009 +
...0010 +
...00011 + ...
now, the 1 from the 10 overlaps with the 9. As a result, there's a 1 that carries over to the eight, putting a 9 where there was an 8, and a 0 where there was a 9. In fact, because of the 1's in the 10's place of the numbers that follow, the sequence of numbers climbs onwards, until the next skip when that 1 changes to a 2. That is, the result of this sum after all the carries are accounted for is
...9012...
which gives us that characteristic "skip" two places back from $10^n$. Thus, the repeating decimal is $ 0.\overline{012345679}$, as we know. With a similar analysis, we find that there is always a skip of the $(10^n-1)^{th}$ $n$-digit number in the sequence. This skip is the inevitable result of the fact that our fraction hides the sum of an endlessly rising sequence of consecutive integers, not just the endless loop of $n$-digit integers that happen to come up in the digital representation.
For comparison, the number $ 0.\overline{0123456789}$ has the much less elegant (reduced) representation of $\frac{13717421}{1111111111}$.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
