An set without limit points - Necessarily closed?
The discussion centers on the assertion that a set without limit points is necessarily closed, which is challenged through examples and definitions. It highlights that while a set lacking limit points may seem closed, counterexamples, such as the integers in the real numbers, demonstrate that this is not universally true. The conversation also explores the implications of compact spaces and the definitions of limit points and contact points, emphasizing the need for clarity in these definitions. Participants argue over the correctness of various mathematical assertions and definitions, ultimately concluding that the original claim is false. The dialogue underscores the complexity of topology and the importance of precise terminology in mathematical discourse.
Extropy
Definitions:
"x is a limit point of A" = "All neighborhoods of x contain an infinite amount of points of A"
"x is a contact point of A" = "All neighborhoods of x contain at least one point of A"
"X is a centered system of closed sets" = "\cap A is not empty, where A is any finite subset of X, and where X is a set of closed sets."
In some book of mine, in some proof of a theorem, the author implicitly asserted for some set X that "Since X is a set without limit points, X is closed."
Now, I do not really know how to prove that--in fact, I think it may be false.
For example take the space to be the set of integers. Let the open sets be any set of non-negative integers, sets of the form {a, -a} where a is any natural number, any unions of the above sets, and the empty set. Let N be the set of natural numbers. Surely N is without limit points--in fact, no element of the space is a limit point of any set since all elements of the space have a finite neighborhood. However, surely -1, which is not a an element of N, is a contact point.
Note: this is what the author stated:
"Theorem: If T is a compact space, then any infinite subset of T has at least one limit point.
Proof: Suppose T contains an infinite set X with no limit point. Then T contains a countable set X=\{x_1,x_2,...,x_n,...\} with no limit point. But then the sets X_n=\{x_n,x_{n}_{+1} ,...\} (n=1, 2, ...) form a centered system of closed sets in T with an empty intersection, i. e. T is not compact."
Mathematics news on Phys.org
A set is closed if its complement is open, now if X every point of it is not a limit point, then obviously the limit points of a sequence of points in X, are in X^c, now you should show, that X^c contains an open sphere, which is basically proving that there exists a point P_n such that for every r>0, and every P in the discussion set, we have that: |P-P_n|<r, which is the definition of a limit point.
If a set is closed it contains all its limit points, or stated differently, a set isn't closed if it doesn't contain at least one of its limit points. So if a set has no limit points, it must be closed.
"If a set is closed it contains all its limit points" but the converse true?
For example, consider the two-element space T= ({0, 1}, {{}{0}{0,1}}). {0} does not have any limit points, but it is not closed, since {0,1}-{0}={1} is not an open set.
This is clearly wrong: The integers as a subset of R with the usual topology is not closed and has no limit points.
Actually, the integers do form a closed set in R with the usual topology, since it contains all its contact points (or, formulated another way, the union of the sets (a, a+1) where a is any integer is an open set, which is the complement of the integers.)
This is false.
I assume that the X above is related to the X below.
The sets X_n are not a priori closed: countable unions of closed sets are not guaranteed to be closed. I can only presume that the author has some other result in mind that utilizes the fact that T is compact.
But, if a set S did not have any limit points,and it was not closed, you may
say that the set of limit points of S is the empty set. Then saying that S is
not closed would imply that S does not contain the empty set, which cannot happen.
In addition, as I think someone above said, if S did not have limit points,
then you may consider X-S (X ambient space, assuming S is a subspace).
Then, for any x in X-S , there must be a 'hood ('hood=neighborhood) V_x
of x, such that V_x does not intersect S , otherwise x would be a limit
point of S . That gives you, for every x in X-S , a 'hood of x contained
in X-S . Then X-S is open, and S is closed.
Actually, 1 is a limit point of {0}, since every 'hood (neighborhood) of
1, specifically {0,1}, intersects {0}.
I believe that we should stick with proper english, and not with english from the hood.
But with the definition of limit point being "a point which contains an infinite amount of points in A in all its neighborhoods," no set in that space can have a limit point, since they are all finite sets. Perhaps the statement would work if the definition was replaced by "a point x which contains at least one point in A-{x} in all its neighborhoods" but it does not work with the current definition of limit point.
To extropy:
Well, I am going by Borowski and Borwein's Dictionary of math's def:
Cluster point, limit point, accumulation point:
"A point every punctured neighborhood of which has a non-empty intersection with a given set; ...". and no xception is made for finite spaces. I guess it comes down to the definition you're using. So,
to sum it up, I am right under my definition, and you are right under
yours, I believe.
But I don't know which one we should use. Problem is if we do not have limit points, we cannot talk about convergence, etc. , so that neither of the sequences : 0,0,0,... nor 1,1,1,... would converge.
To Loop Quantum Gravity:
I was just joking a little, just for fun. I am not writing entire messages
in that style, I just like to drop jokes like that everyonce in a while. Math
can get too intense at times, and I thought that may help.
If I was writing fully in that style, or if most of my posts were not
relevant to the questions, I would agree with you. Still, I guess this
is a democracy , and if many people dislike it, I will drop it. Sound fair?
I don't have a problem with it, but if it were for short or fun then why have you used it with brackets that it means neighbourhood more than once? (-:
Just an FYI, the normal abbreviation is nbd.
To Quantum Loop:
Well, I decided to define it twice because I did not know wether everyone would read both my posts, so someone who had no read the post where I first used the abbreviation would not understand it.
To Matt:
Yes, Nbd is the usual abbreviation, but using it would defeat (at least my) purpose of giving (at least myself) a relaxation break , by using something out of the ordinary.
I don't want to go too far off, but usage of standard words triggers
or reinforces existing moods. Using something different or off-beat may , at best, shock you out of a state of stress, and , at worse (or so I believe) it may be just a small distraction.
Again, if this upsets people, I will drop it. Anyway, peace, and go with
the force, go with the m*a (f=m*a) :)
P.S: I wrote a title for a HW I did on Latin Squares: " I am Latin, but
I ain't no square" ( I am Latin, from Venezuela, BTW). This is the
( I admit low-brow, low-quality) humor I am aiming for.
it's dp/dt, but i let you off the hook. (-:
