AN Standard 37 degree taper fitting
Edward Camic
Does anyone know the reasoning behind the decision to use 37 degrees for the conical taper on an AN fitting? I understand this is a standard dimension for the fittings, but I am hoping to get a little background on how this came to be.
Early flare fittings had a 30 degree angle. Then the US government got involved and developed a family of 37 degree fittings for use in aircraft. Some good information from Parker: http://blog.parker.com/an-37-flare-vs-industrial-37-flare-fittings-whats-the-difference.
I don't know how they came up with 37 degrees, but we can look at the extremes of possible angles:
1) Very low angle - 5 to 10 degrees. It would be difficult to make the flare, difficult to assemble in a tight space, and difficult to get a good clamp fit while still able to disassemble.
2) Large angle - 90 degrees. Difficult to make the flare (tube cracking, need multiple steps), easy to assemble in a tight space, and easy to get a good clamp fit.
The extremes of angle have different problems, so there is an optimum in between that balances ease of flaring, ease of assembly and disassembly, and getting a reliable leak free connection. Finding the best angle is an optimization problem - the exact angle varies according to how each of the parameters in the optimization is weighted.
Machine tapers are specified by radius change per axial length. That is because the cross-feed on a cutting lathe is geared to the lead-screw by an integer ratio gearbox. The USA units are “inches per foot” so US tapers often show submultiples of 12” per foot.
Tan( 37° ) = 0.753554 which is close to 3/4.
Atan( 3/4 ) = 36.87° and I think that is where that choice of taper comes from.
To cut a 30° taper would require an irrational gear ratio of 0.57735 which is not possible with a simple gearbox.
Super helpful and interesting, thanks everyone!
