Analytic solution of this, Advice.
  • Thread starter Thread starter Clausius2
    Analytic solution
Clausius2
I am looking for the analytic solution of this ODE (if it were one):
s^2G''+sG'-(1+s^2+s\text{coth}(s))G=-4s^2e^{-s}
I have solved this equation numerically, it only gives one physically realizable configuration rejecting conveniently one of the homogenous solutions. I don't have those solutions BUT I have the asymptotic behavior of G(s), which turns out to be G\sim As^{\sqrt{2}} and G(s)\sim se^{-s}} for small and large s respectively, where A is a coefficient that I have worked out by means of a linear shooting.
When writting it on Maple in OdeAdvisor, it says to me that it is a Linear ODE (easy thing to know) and with Linear Symmetries. Does this last thing have something to do with Lie Symmetries?. May this ODE be solvable employing that theory, I don't have a clue.
Thanks.
For small s we can start with the equation
<br /> u^{\prime \prime} +\lambda u^{\prime}<br /> +\lambda^{\prime}u=\gamma e^{\int \eta ds}<br />
and make the substitution
<br /> u = G(s) e^{\int \eta ds} <br />
This will give us the equation
<br /> G^{\prime \prime}(s) + (2 \eta + \lambda) G^{\prime}(s) <br /> + (\eta^{\prime} + \eta^2 + \lambda \eta + \lambda^{\prime}) G(s) = \gamma <br />which if we set
<br /> \lambda = \frac{1}{s} - 2 \eta<br />
and
<br /> \gamma = -4 e^{-s} <br />
gives us
<br /> G^{\prime \prime}(s) + \frac{G^{\prime}(s)}{s}<br /> + ( \frac{\eta}{s} - \eta^{\prime} - \eta^2 - \frac{1}{s^2}) G(s) = -4e^{-s}<br />
which we can see is similar to your equation once we divide it by s^2.
<br /> G^{\prime \prime}(s) + \frac{G^{\prime}(s)}{s}<br /> - ( \frac{1}{s^2} + 1 + \frac{\coth{(s)}}{s}) G(s) = -4e^{-s}<br />Now the next bit is to match the G(s) term with your equation. So,
<br /> \frac{\eta}{s} - \eta^{\prime} - \eta^2 - \frac{1}{s^2} <br /> = -\frac{1}{s^2} -1 - \frac{\coth{(s)}}{s} <br />
Hence we need to choose an $\eta$ that fits. If we try substituting
<br /> \eta = \coth{(s)} \pm \frac{\sqrt{2}}{s}<br />
we get, with some fiddling,
<br /> \frac{2(1 - \sqrt{2})}{s} \coth{(s)} = <br /> \frac{2(1 - \sqrt{2})}{s^2} <br />
or
<br /> \frac{2(1 + \sqrt{2})}{s} \coth{(s)} = <br /> \frac{2(1 + \sqrt{2})}{s^2} <br />
So, for small s, where we can make the assumption that
<br /> \coth{(s)} \simeq \frac{1}{s}<br />
we therefore have a solution.
The only thing left is to solve the very first equation.
By inspection we can see that it can be integrated directly to yield
<br /> u^{\prime} + \lambda u = \int \gamma e^{\int \eta ds} ds<br />
which is straightforward to solve for u, and hence G.
For large, positive s we can use the same method, except in our choice of \eta. If we choose
\eta = \coth{(s)} - 2
and plug this into
and rearrange, we get
<br /> (\frac{2}{s} + 4) \coth{(s)} = \frac{2}{s} + 4
which as s tends to (positive) infinity, coth(s) tends to 1, and this becomes true.
You can then solve for u and G as above.
will get back to this later...
Mathew! THANKS A LOT MAN!. Keep on posting, I will keep track of every line. At first sight it seems you don't find a closed form though...it's an asymptotic behavior isn't it?.
Hey man. I re-did all the steps, and it pretty much works. The only problem is that finding an exact solution of:
\eta^2+\eta&#039;-\eta/s=1+coth(s)/s
seems a pretty difficult task. It's a Riccatti equation. It would be nice to have it for closing the problem. I will mess around with some books to look for a solution (Maple doesn't say anything as always), and also I am going to see how good is your asymptotic approximation compared with the one (coming from Frobenius at s=0 and approximating scoth(s)\sim s for large s) that I had before. Where did you find this stuff?. I mean, you have the book where this stuff can be found?.
Thanks.
Sorry, no book - I've just been fiddling around with it, seeing what comes up.
Yeah - for the general case I can't find a solution (one that doesn't involve an approximation), but I'll keep looking.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
