Analytical solution for dx/dt = (a-x)/(b-t) - cx
  • Level: Graduate
  • Thread starter Irid
9 replies · 2K views · last reply
Irid
I have a differential equation
[tex] \frac{dx}{dt} = \frac{a-x}{b-t} - cx[/tex]
but no idea if there is an analytical solution :(
I tried the integrating factor method, but I run into a e^(-x)/x^2 kind of integral, which I think doesn't have an analytical expression.. Help, please?
With some manipulation,your equation can get the form below:
[itex] -(t-b)(\dot{x}+cx)+x=a[/itex]
Now take a solution like:
[itex]x=\sum_0^{\infty}a_n(t-b)^{n+r}[/itex]
We have:
[itex] \dot{x}=\sum_0^{\infty}a_n (n+r) (t-b)^{n+r-1}[/itex]
If you substitute the x and [itex]\dot{x}[/itex] in the homogenous DE,you will find:
[itex] -\sum_0^{\infty}a_n(n+r)(t-b)^{n+r}+\sum_0^{\infty}a_n(t-b)^{n+r}-\sum_1^{\infty}ca_{n-1}(t-b)^{n+r}=0[/itex]
Where I have changed the summation index in the third term from n to n-1 to make the powers of (t-b) the same in all summations.
Now to make the summations start from a common n,I get the n=0 terms out of the first two summations:
[itex] -a_0r(t-b)^r+a_0(t-b)^r=0[/itex]
Which gives [itex]r=1[/itex]
Then you can take all the terms in one summation and equate the coefficient of [itex](t-b)^{n+r}[/itex] to zero to get a recursion relation which determines the series solution.
Then you should add a/(c+1) to get the solution to the in-homogenous equation.
so you mean to say that there is no solution in terms of elementary functions?
I just used www.wolframalpha.com to solve your equation and this is the result:
http://www3.wolframalpha.com/Calculate/MSP/MSP1811gi6c448044hadb10000242868gf692egc43?MSPStoreType=image/gif&s=12&w=389.&h=22.
With [itex]x \rightarrow t[/itex] and [itex]y \rightarrow x[/itex]
And Ei(x) is the exponential integral which you can find its values in some tables of functions.
That is a linear differential equation.
[tex]\frac{dx}{dt}+ (\frac{1}{b- t}+ c)x= \frac{a}{b- t}[/tex]
An "integrating factor" is a function u(t) such that
[tex]\frac{dux}{dt}= u\frac{dx}{dt}+ u(\frac{1}{b- t}+ c)x[/tex]
Since
[tex]\frac{dux}{dt}= u\frac{dx}{dt}+ \frac{du}{dt}x[/tex]
that means we must have
[tex]\frac{du}{dt}= \frac{1}{b- t}+ c[/tex]
[tex]du= \left(\frac{1}{b- t}+ c\right)dt[/tex]
u(t)= -ln|b-t|+ ct
That is, the original differential equation is
[tex]\frac{d}{dt}\left(x(t)(-ln|b- t|+ c\right)= (-ln|b- t|+ ct)\frac{a}{b- t}[/tex]
so that
[tex]x(t)(-ln|b- t|+ c)= \int (-ln|b-t|+ ct)\frac{a}{b- t} dt[/tex]
Let u= b- t so that du= dt and the right side becomes
[tex]b\int \frac{ln|u|}{u}du- ac\int \frac{b- u}{u}du[/tex]
In the first integral let v= ln|u| so that dv= du/u and that integral becomes
[tex]\int v dv= (1/2)v^2= (1/2)(ln|u|)^2= (1/2)(ln|b- t|)^2[/tex]
In the second integral (b-u)/u= (b/u)- 1 and its integral bln|u|- u= b ln|b- t|- |b- t|.
putting those together
[tex]x(t)(-ln|b- t|+ c)= (1/2)(ln|b-t|)^2+ b ln|b- t|- |b- t|)[/tex]
Finally,
[tex]x(t)= \frac{ln|b-t|)^2+ b ln|b- t|- |b- t|}{2(-ln|b- t|+ c)}[/tex]
Since
u(t)= -ln|b-t|+ ct
so that
Finally,
This can't be right. If you set c=0, the solution is simply x= at/b, and your equation doesn't reduce to that. Also, if b -> infinity, the solution tends to x = Ae(-ct), which I see no trace of in your calculations.
Here's the problem:
u(t)= -ln|b-t|+ ct
We should have:
[itex] \frac{du}{dt}=u(\frac{1}{b-t}+c)[/itex]
Which gives an integrating factor of:
[itex] u=\frac{e^{ct}}{b-t}[/itex]
And we will have:
[itex] \frac{xe^{ct}}{b-t}=\int \frac{ae^{ct}}{(b-t)^2}dt[/itex]
And this gives the answer that I tried to present in the post #6 but it seems that its image is deleted from the server of the wolframalpha.
The answer is:
[itex] -{{\rm e}^{-ct}}a \left( -{{\rm e}^{ct}}+{{\rm e}^{cb}}{\it Ei}<br /> \left( 1,cb-ct \right) cb-{{\rm e}^{cb}}{\it Ei} \left( 1,cb-ct<br /> \right) ct \right) [/itex]
Where:
[itex] Ei(a,z)=\int_1^{\infty} e^{-tz}t^{-a}dt[/itex]
is the exponential integral and you can find its values in some mathematical tables.
Just trying :|
Isn't it a linear DE? I'm not really good at these kinds of things, but here's my try:
I'm not sure, I don't really go for analytic solutions :|EDIT: I looked at how wolframalpha would integrate the right-hand integral and it generated an Ei(-c(t-b)) o-o
  • Handwritten derivation rearranging dx/dt = (a - x)/(b - t) - cx into linear form, ending with x e^(integral of (1 + cb - ct)/(b - t) dt) = integral of a/(b - t) e^(integral of (1 + cb - ct)/(b - t) dt) dt + c.
