Analytical solution for dx/dt = (a-x)/(b-t) - cx
  • Context: Graduate
  • Thread starter Thread starter Irid
9 replies · 2K views
Irid
I have a differential equation
[tex] \frac{dx}{dt} = \frac{a-x}{b-t} - cx[/tex]
but no idea if there is an analytical solution :(
I tried the integrating factor method, but I run into a e^(-x)/x^2 kind of integral, which I think doesn't have an analytical expression.. Help, please?
With some manipulation,your equation can get the form below:
[itex] -(t-b)(\dot{x}+cx)+x=a[/itex]
Now take a solution like:
[itex]x=\sum_0^{\infty}a_n(t-b)^{n+r}[/itex]
We have:
[itex] \dot{x}=\sum_0^{\infty}a_n (n+r) (t-b)^{n+r-1}[/itex]
If you substitute the x and [itex]\dot{x}[/itex] in the homogenous DE,you will find:
[itex] -\sum_0^{\infty}a_n(n+r)(t-b)^{n+r}+\sum_0^{\infty}a_n(t-b)^{n+r}-\sum_1^{\infty}ca_{n-1}(t-b)^{n+r}=0[/itex]
Where I have changed the summation index in the third term from n to n-1 to make the powers of (t-b) the same in all summations.
Now to make the summations start from a common n,I get the n=0 terms out of the first two summations:
[itex] -a_0r(t-b)^r+a_0(t-b)^r=0[/itex]
Which gives [itex]r=1[/itex]
Then you can take all the terms in one summation and equate the coefficient of [itex](t-b)^{n+r}[/itex] to zero to get a recursion relation which determines the series solution.
Then you should add a/(c+1) to get the solution to the in-homogenous equation.
so you mean to say that there is no solution in terms of elementary functions?
The series you find may come out to be the power series corresponding to an elementary function.But it only may.
argh :(
better integrate numerically then...
I just used www.wolframalpha.com to solve your equation and this is the result:
http://www3.wolframalpha.com/Calculate/MSP/MSP1811gi6c448044hadb10000242868gf692egc43?MSPStoreType=image/gif&s=12&w=389.&h=22.
With [itex]x \rightarrow t[/itex] and [itex]y \rightarrow x[/itex]
And Ei(x) is the exponential integral which you can find its values in some tables of functions.
That is a linear differential equation.
[tex]\frac{dx}{dt}+ (\frac{1}{b- t}+ c)x= \frac{a}{b- t}[/tex]
An "integrating factor" is a function u(t) such that
[tex]\frac{dux}{dt}= u\frac{dx}{dt}+ u(\frac{1}{b- t}+ c)x[/tex]
Since
[tex]\frac{dux}{dt}= u\frac{dx}{dt}+ \frac{du}{dt}x[/tex]
that means we must have
[tex]\frac{du}{dt}= \frac{1}{b- t}+ c[/tex]
[tex]du= \left(\frac{1}{b- t}+ c\right)dt[/tex]
u(t)= -ln|b-t|+ ct
That is, the original differential equation is
[tex]\frac{d}{dt}\left(x(t)(-ln|b- t|+ c\right)= (-ln|b- t|+ ct)\frac{a}{b- t}[/tex]
so that
[tex]x(t)(-ln|b- t|+ c)= \int (-ln|b-t|+ ct)\frac{a}{b- t} dt[/tex]
Let u= b- t so that du= dt and the right side becomes
[tex]b\int \frac{ln|u|}{u}du- ac\int \frac{b- u}{u}du[/tex]
In the first integral let v= ln|u| so that dv= du/u and that integral becomes
[tex]\int v dv= (1/2)v^2= (1/2)(ln|u|)^2= (1/2)(ln|b- t|)^2[/tex]
In the second integral (b-u)/u= (b/u)- 1 and its integral bln|u|- u= b ln|b- t|- |b- t|.
putting those together
[tex]x(t)(-ln|b- t|+ c)= (1/2)(ln|b-t|)^2+ b ln|b- t|- |b- t|)[/tex]
Finally,
[tex]x(t)= \frac{ln|b-t|)^2+ b ln|b- t|- |b- t|}{2(-ln|b- t|+ c)}[/tex]
Since
u(t)= -ln|b-t|+ ct
so that
Finally,
This can't be right. If you set c=0, the solution is simply x= at/b, and your equation doesn't reduce to that. Also, if b -> infinity, the solution tends to x = Ae(-ct), which I see no trace of in your calculations.
Here's the problem:
u(t)= -ln|b-t|+ ct
We should have:
[itex] \frac{du}{dt}=u(\frac{1}{b-t}+c)[/itex]
Which gives an integrating factor of:
[itex] u=\frac{e^{ct}}{b-t}[/itex]
And we will have:
[itex] \frac{xe^{ct}}{b-t}=\int \frac{ae^{ct}}{(b-t)^2}dt[/itex]
And this gives the answer that I tried to present in the post #6 but it seems that its image is deleted from the server of the wolframalpha.
The answer is:
[itex] -{{\rm e}^{-ct}}a \left( -{{\rm e}^{ct}}+{{\rm e}^{cb}}{\it Ei}<br /> \left( 1,cb-ct \right) cb-{{\rm e}^{cb}}{\it Ei} \left( 1,cb-ct<br /> \right) ct \right) [/itex]
Where:
[itex] Ei(a,z)=\int_1^{\infty} e^{-tz}t^{-a}dt[/itex]
is the exponential integral and you can find its values in some mathematical tables.
Just trying :|
Isn't it a linear DE? I'm not really good at these kinds of things, but here's my try:
I'm not sure, I don't really go for analytic solutions :|EDIT: I looked at how wolframalpha would integrate the right-hand integral and it generated an Ei(-c(t-b)) o-o
