Analyzing a Wave: Homework Solutions
  • Thread starter Thread starter aliaze1
    Wave
7 replies · 3K views
aliaze1
http://photo.ringo.com/230/230997145O975467146.jpg
λ=v/f
k=2π/λ
ω=2πf
T=1/f
v=ω/k
V(string) = √(Tension of string/μ), where μ = denisty
D(x,t) = A sin (kx - ωt + Φ)
I found the maximum displacement as 2, found from the given equation
The third part seemed to be the next simplest, so using v=ω/k, I calculated 638/12.57 as the speed, which was incorrect
To my knowledge, this speed is needed to calculate the tension of part 1
i guess it is possible, but that is the exact question copied word-for-word
what does d(D(x,y))/dt means?
I just realized that the third part is not required to complete the first part,
using v=ω/k, and plugging this v into
V(string) = √(Tension of string/μ), where μ = denisty;
I get an answer of 12880.7, which is essentially 12.9 *103...the answer however is simply 12.9...
where am i going wrong?
thanks
I thought it had to do with the amplitude being in centimeters, so I divided by 100, but that still is 129 not 12.9...
Make sure all units are consistent. The linear mass density is 5 g/ m as opposed to 0.05 g /cm or 0.005 kg/m. Perhaps that is where one is off by 3 or 1 order of magnitude depending on the values one uses. Tension should be in Newtons (for SI/mks).
thanks!, makes sense
