Analyzing One-Dimensional Collisions (Physics Lab)
To calculate the initial velocity of the first cart in a one-dimensional collision, it is important to consider the timing of the measurement. The initial velocity is technically measured as the cart leaves your hand, calculated using the formula Δd/Δt from the first two data points. However, for a more accurate approximation, it is suggested to use the distance just before the collision and the time just before impact. This method accounts for any changes in velocity prior to the collision. Understanding these nuances will help in accurately determining the momentum during the experiment.
toittoiger
I am doing a Physics Lab where you have to measure initial and final velocities of two carts colliding in order to find the momentum. In this first category, you push a cart with a bumper into another cart with a bumper so that the first one completely stops right when it hits the second one. I am just wondering how you would calculate the initial velocity of the first cart I had to push off. Is the initial velocity right before it hits the cart or when it leaves my hand...etc. If you could please tell me what you think the initial velocity might be from this following data, that would be great. Here is the data:
t (s) d (m) ∆d (m) ∆t (s) v (m/s)
0 0
0.1 0.01 0.01 0.1 0.1
0.2 0.027 0.017 0.1 0.17
0.3 0.062 0.035 0.1 0.35
0.4 0.114 0.052 0.1 0.52
0.5 0.19 0.076 0.1 0.76
0.6 0.287 0.097 0.1 0.97
0.7 0.39 0.103 0.1 1.03
0.8 0.491 0.101 0.1 1.01
0.9 0.588 0.097 0.1 0.97
1 0.682 0.094 0.1 0.94
1.1 0.772 0.09 0.1 0.9
1.2 0.858 0.086 0.1 0.86
1.3 0.9431 0.0851 0.1 0.851
1.4 1.022 0.0789 0.1 0.789
1.5 1.097 0.075 0.1 0.75
1.6 1.16 0.063 0.1 0.63
1.7 1.227 0.067 0.1 0.67
1.8 1.244 0.017 0.1 0.17
Strictly speaking, the initial velocity is just as it leaves your hand which would be
Δ d/Δ t for the first two times in your data list. However, that's really assuming that velocity remains constant until the collision. You might want to consider (distance at collision- distance at start)/(time of collision- time of start) as a better approximation.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
