Angle of the diagonal of a cube
  • Context: High School
  • Thread starter Thread starter DaveC426913
    Angle Cube
The discussion revolves around determining the angle between the diagonal of a cube and its edges at a vertex, as well as the angle between the diagonal and the plane of the cube's face. Participants explore various mathematical approaches, including vector mathematics and trigonometric functions, while also considering implications in other geometric contexts.
  • One participant seeks to find the angle without using trigonometry, speculating it might be around 31.8 degrees.
  • Another participant suggests using vector math, stating the diagonal can be represented as (1,1,1) and the edge as (1,0,0), leading to a calculation involving the dot product.
  • Calculations presented yield an angle of approximately 54.74 degrees between the diagonal and the edges.
  • Some participants express uncertainty about the angle between the diagonal and the plane of the base, with values suggested around 48.19 degrees and 35.26 degrees.
  • Disagreement arises regarding the correct angle, with some participants asserting it should be less than 45 degrees based on geometric reasoning.
  • Further calculations and corrections are made, with one participant realizing a simpler method to find the angle as 90 degrees minus the angle to the edge.
  • Connections are made to other geometric shapes and concepts, such as the magic angle and its relevance in quantum mechanics.
  • Discussion extends to the potential for exploring angles in regular polyhedra and their mathematical properties.
Participants do not reach a consensus on the exact angles, with multiple competing values presented and debated. The discussion remains unresolved regarding the precise angles and methods used to calculate them.
Some calculations depend on specific assumptions about the vectors and their orientations. There are unresolved mathematical steps and differing interpretations of trigonometric functions involved in the angle calculations.
This discussion may be of interest to those studying geometry, trigonometry, or physics, particularly in relation to polyhedra and their properties.
DaveC426913
2025 Award
TL;DR
What can I do to figure out the angle between the diagonal of a cube and any of the 3 edges at a given vertex?
I've looked for this in a hundred places but I keep finding the unit length of the diagonal (root 3). I want to find the angle.
i.e. the angle between the cube's diagonal and its three edges at a vertex (all three angles will be identical, of course).
I guess I hoping to figure it out without trig. I really only need it to one (or zero) decimals of a degree, really.
(Hey, I wonder if it will just be .707 of 45 degrees... or about 31.8 deg.)
Mathematics news on Phys.org
Is this a homework assignment? It sure looks like one.
Okay on a cube face of a 1" cube, the diagonal is sqrt(2)
The diagonal you want forms a triangle with the cube face diagonal as one side and 1 as the other of a right triangle so the tangent of the angle would be 1/sqrt(2).
In radians, its about 0.615 or 35.2 degrees.
The complement of that is 90-35.2 = 54.8 degrees which would be the angle with a cube edge.
You can do this with some simple vector math which does involve trig but barely.
The edge of the cube is a vector like (1,0,0), the main diagonal is (1,1,1). The dot product of these two is equal to cosine of the angle times the product of the norms of the vectors. Then you just need a little algebra and take arccosine.
Your intuition is wrong. If you project the diagonal onto a face it makes a 45 degree angle with an edge. When you let it swing out into the third dimension the angle will get bigger, not smaller
It isn't homework. It's part of the project I've been working on.
  • Haha
If you're not sure how to do that computation in my previous post, the dot product is just summing the product of the coordinates of the vectors.
1*1+1*0+1*0=1.
The two vectors have norms (aka lengths) computed by the pythagorean theorem
##\sqrt{1^2+1^2+1^2}=\sqrt{3}## and##\sqrt{1^2+0^2+0^2}=1##
the statement I made is the dot product is the product of the lengths and cosine of the angle, so
##1=\sqrt{3}*1*\cos(\theta)##
##\theta=\arccos(1/\sqrt{3})##
plugging that into a calculator gives 54.74 degrees.
Thanks. Never got the hang of arccoses and secant...
54.74. Interesting... That's the same angle that keeps coming up when I'm rotating tetrahedra in Blender. Almost like it's not a coinky-dink.
How about angles in any regular polyhedron? Any magic numbers there? Would make for an interesting problem I think: Find a polynomial for which a root is a magic number of a dodecahedron.
And if what was wanted was the angle between the diagonal and the plane of the base, that would be about 48.19°. 35.26° (edited to correct my error in forgetting to take a square root)
The formula that @Office_Shredder used for the angle ##\theta## between two vectors ##\vec u## and ##\vec v## is this:
$$\cos(\theta) = \frac{\vec u \cdot \vec v}{|\vec u| |\vec v|}$$
Post #5 shows the calculations of the dot product in the numerator, and the two vector magnitudes.
It's really not all that complicated. In words, arccos(x) means "the angle whose cosine is x. For the purposes here, arccos is the same as ##\cos^{-1}##, so working in degrees, arccos(1/2) = ##\cos^{-1}(1/2)## = 60°. The other way around, it is ##\cos(60°) = 1/2##. All of the so-called circular trig functions -- sine, cosine, tangent, cosecant, secant, cotangent -- have inverses
No, I think this number is less than 45 degrees, because (1,0) and (1,1) form a 45 degree angle, so (1,1,0) and (1,1,1) should form an angle of less than 45 degrees. I tried doing the same computation and got 35.26 degrees.
Yep, you're right. I did some simplification of ##\frac 2 {\sqrt 6}## to ##\sqrt { \frac 2 3}##, which is correct, but then neglected to actually take the square root before doing the inverse cosine. Doh!
I'll edit my earlier post.
I realized the simpler way to do it which is that that angle is 90-angle to the edge.
TeethWhitener said:
It crops up in interesting places:
https://en.m.wikipedia.org/wiki/Magic_angle
I was thinking about Bell's Theorem recently and, specifically, whether I could more directly show that hidden variables were inadequate to reproduce the predictions of QM. I didn't come up with anything, but I noticed that:
If a particle is in the spin-up state in the direction ##(1, 1, 1)## then the probability that it is found to be spin-up in any of the x, y or z directions is given by ##\cos^2 \frac \theta 2##, where ##\theta## is the magic angle. This gives a probability of: ##\frac 1 2 (1 + \cos \theta) = \frac 12 (1 + \frac 1 {\sqrt 3})##, which is about ##0.79##.
That's a huge correlation.
The angle of the cube diagonal with the cube face plane is about 35.2 degrees ie arctan(1/sqrt(3))
I believe it is the arc sine, and not the arc tan. It's the arc tan of (1/sqrt(2)).
Yes, you can use the same idea using the inner product of the vectors ##(1, 1, 1)## and ##(1,1)## to get the cosine of the angle between a diagonal and a face: $$\sqrt 3 \sqrt 2 \cos \theta = 2 \ \implies \ \cos \theta = \sqrt{\frac 2 3} \ \implies \ \sin \theta = \sqrt{\frac 1 3} \ \implies \ \tan \theta = \sqrt{\frac 1 2}$$
Yes you’re right. I misremembered my earlier post and used sqrt(3) instead of sqrt(2).
This information may be more than is necessary to solve my brass tubing project, but I will keep a watchful eye to see if any quantum mechanical peculiarities creep in. :wink:
  • Haha
There is also the magical latitude 35.26 ° , quite near my home. From there, you can set down a cube and have the axis point to the north star. Same goes for the octahedron! These solids could go farther and have sundials affixed to each face. These things set flat at this latitude.
  • Love
  • Wow
OK. You are now tasked with generalizing your find into Helios' Principle.
I live at 45N. What polyhedron can I use?
What about other members? C'mon everybody - chime in!
It looks like you can use a Rhombic Dodecahedron. It would have an inner long axis that aligns with the Earth axis.
  • · Replies 33 ·
  • · Replies 16 ·
