Angled Rod w Float Attached -- Force of Float
The discussion revolves around calculating the upward force exerted by a float attached to a rod submerged at a 45-degree angle in water. Participants explore the implications of buoyancy, the density of the float, and the geometry of the system, including how these factors affect the force as the float moves upward. The conversation includes theoretical considerations and practical applications related to fluid mechanics and lever systems.
  • Experimental/applied
  • Some participants assert that the float exerts a vertical buoyant force of 50 lbs due to the water it displaces, while others question the float's density and weight.
  • There is a discussion about Archimedes' principle and how it applies to the situation, with some participants emphasizing the need for clarity on the float's characteristics.
  • One participant suggests that the upward force can be calculated using the formula: Force = buoyancy * Cos(declination angle), while another questions if Sin should be used instead depending on the angle's measurement.
  • A participant mentions the need for additional information regarding the system's setup, including whether the rod is balanced and how the angle affects equilibrium.
  • There is a proposal for a water-fed engine, leading to questions about whether it is a turbine or a perpetual motion machine, with participants clarifying their intentions.
  • Concerns are raised about the stability of the system and whether the heavier side of the lever will always point straight downward or at an angle.
Participants express differing views on the characteristics of the float and how they affect the calculations. There is no consensus on the exact approach to calculating the upward force or the implications of the rod's angle on equilibrium.
Participants note that the lack of a drawing or detailed explanation makes it difficult to fully understand the system being discussed. There are also mentions of missing assumptions regarding the float's density and the overall setup of the rod and float system.
This discussion may be of interest to individuals exploring fluid mechanics, buoyancy, and lever systems, particularly in practical applications such as engineering projects or experimental setups.
mrapple
Hi!
A ridged rod is submerged in water at a 45 degree angle toward the bottom of a tank of water. The upper end of the rod is fixed to a pivot point and so, the lower end of the rod is able to move around that pivot point. The lower end of the rod has a float attached to that displaces 50lb of water. The rod length is 15 feet. How do I calculate how many Lb of upward force the float has at any given point along its' journey upwards toward the surface. Thanks!
Welcome to PF. :smile:
What is the application? Is the upper hinge attached to a dock or something?
The float will always have a vertical buoyant force of 50 lbs due to it's displacement.
But we don't know the float density, or how much the float weighs.
According to Archimedes' principle, the float exerts an upward force on whatever is attached to it that is equal to the weight of the water it displaces. How much water weight does the float displace?
If the float has a density over one, or a mass of 50 lbs or more, it will sink.
Forgive me, but a float that sinks would not be called a "float"; it could be called a "sinker". I think the intention of the problem's author is that the float exerts an upward force of 50 lbs. Otherwise, we would be provided with more information. It is entirely possible that @mrapple , being new, has not provided all there is.
Then the question:
is answered.
I suspect, once the correct question is identified, the answer will include;
Force = buoyancy * Cos( declination angle )
Agreed. After lots more personal research on my part, I think I've decoded the OP's question...
http://waynesthisandthat.com/birds.html
  • Love
Baluncore said:
Then the question:
is answered.
Do I use Sin instead if the angle is decreasing right?
That will depend on which way you measure the angle, from the vertical or the horizontal. But if the angle is 45°, it does not make any difference.
Terms to google
I am trying to produce a water fed engine. This isn't homework. I do not have a physics degree. I can't find the answer online as when you google equilibrium they all refer to a situation where the rod is perpendicular to the ground. You said it won't make a difference at a 45 degree angle. What if the 1st class lever is at a 60 degree angle and is outside of the tub of water (i.e. just in the air). Can you give me some directions as to terms to google or what equations should I use?
Thanks
Do you mean like a water turbine to generate electricity, or a perpetual motion machine?
Turbine. Perpetual motion machines don't work
I know that force times distance on each side is used to calculate equilibrium. What I am trying to figure out is if the heavier side will always cause it to point straight downward or somewhere in between at an angle not perpendicular to the ground?
If the the lever is not balanced then unless there is some other constraint you have not mentioned it will reach equilibrium only when it is vertical.
Without a drawing, it is hard to guess what you mean. Perhaps there is a float in the water and a weight attached to a portion of the rod that extends out of the water. In that case, I see no possibility for a stable equilibrium other than directly vertical or flat horizontal.
What is the rod + float expected to do anyway? Control a throttle valve or fill valve?
Yes, I think a drawing and an explation of what you are trying to do (rather than what you are trying to calculate) is needed.
  • · Replies 66 ·
  • · Replies 29 ·
