Angular magnification and the magnifying glass
1 reply · 8K views
Reservist
An engraver uses a magnifying glass (f=9.5 cm) to examine some work. The image he sees is located 25 cm from his eye, which is his near point. A) what is the distance between the work and the magnifying glass? b) what is the angular magnification of the magnifying glass?
M= (1/f -1/di)N
1/di + 1/do = 1/f
A) 1/25 + 1/do= 1/9.5 do= 15.3 cm
b) m=(1/9.5 - 1/25) 25 M= 1.63
Can some one check/ correct my work, not sure if I'm using the correct formulas. Thank you.
This is a virtual image. Using the sign convention you have, the image distance is negative. So $$\begin {eqnarray*}
\frac 1{d_o}&=&\frac 1f-\frac 1{d_i}\\
&=&\frac 1 {9.5}-\frac 1 {-25}\end {eqnarray*} $$I make that ##d_o=6.88##cm for part (a).
Angular magnification is just ##M=-d_i/d_o##. Not sure what your formula is since you don't define N. In this case I make it 25/6.88=3.63 for part (b).
