Angular magnification of an out-of-focus eyepiece
  • Context: Graduate
  • Thread starter Thread starter chromatic
    Angular Magnification
The discussion revolves around the calculation of angular magnification and image distortion in an eyepiece, particularly when accounting for defocus due to myopia or hypermetropia. Participants explore the implications of lens movement and the resulting ray behavior on magnification and distortion, with a focus on simulation techniques.
  • One participant seeks to understand how to calculate magnification as a function of distance from the optical axis when rays exiting the eyepiece are not parallel due to lens corrections for myopia/hypermetropia.
  • Another participant questions whether the actual image size on the retina would differ significantly when using the eyepiece for normal vision, suggesting that the distortion may not be a major concern.
  • It is proposed that distortion might only change by a couple of percent, but for large fields of view, compensation through an algorithm is necessary, highlighting the need for quantitative values for out-of-focus distortion.
  • A participant mentions the existence of 'stop-shift formulas' but expresses uncertainty about their applicability without knowing how much the stop moves to accommodate defocus.
  • One participant suggests that a simpler thin lens approximation might be feasible instead of a detailed lens layout, depending on the optical power adjustments made for myopia.
  • A later reply indicates that simulations were successfully run using rays from infinity and Gaussian kernel density estimation to compute magnification, with thin lens formulas applied for accommodation simulation.
Participants express varying degrees of concern regarding the impact of distortion and the methods to calculate it, with no consensus on a single approach or solution. Some participants propose alternative methods while others question the significance of the distortion itself.
The discussion includes references to specific formulas and simulation techniques, but there are unresolved assumptions regarding the application of these methods and the conditions under which they hold true.
chromatic
I'm trying to simulate light rays going through an eyepiece to characterize its magnification in function of the distance from the optical axis (image distortion). Attached is a figure showing the simulation console.
Some lenses in the eyepiece are movable to correct for myopia/hypermetropia.
When the object is exactly at the focal point (rays from a single point all exit parallel), magnification is easily calculated from the angle of exiting rays.
HOWEVER, when the lens correct for myopia, the rays exiting from the eyepiece are not parallel, how can I calculate magnification in function of the distance from the optical axis (image distortion) in that case?
Thanks a lot!
Science news on Phys.org
I'm just wondering whether you need to worry about this. If your eye/eyepiece are treated as a compound then will the actual image size on the retina be very different from when the eyepiece is used for 'normal vision?
Probably the distortion will only change by couple of percents, but for big fields of view (~90 degree), the distortion is big and need to be compensated by an algorithm, it would be optimal to have quantitative values for out-of-focus distortion so the algorithm can take that in consideration.
Thanks a lot!
Let me make sure I understand the question- you want to calculate the distortion as a function of defocus?
Yes, distortion as a function of defocus, which is the same as magnification as a function of defocus and image height.
I don't think there's a clean analytic expression. There are the 'stop-shift formulas' (for example http://books.google.com/books?id=kS...ge&q="stop shift formulas" distortion&f=false), but I haven't ever used those, and unless you know how much the stop moves to accommodate your defocus requirement, I don't see how it can be easily used.
I wonder if you simply have to grind through the ray-trace code; have it tell you what the distortion is for a variety of defocus layouts and hope you can fit a curve...
Upon re-reading what you originally asked, tho, I wonder if there is a simpler approach. My guess is that you are simply altering the optical power of the eyepiece to account for myopia, so you may be able to create a (reasonably) simple thin lens approximation instead of the detailed lens layout.
Thank you for your replies, I finally got it to work. I ran the simulations with rays coming from infinity instead of rays
exiting from the object (right to left instead of left to right on figure) and I computed the density of intersection points with the object using Gaussian kernel density estimation. I chose to points with maximum density to calculate magnification. To simulate accommodation, I simply use thin lens formulas to find appropriate initial conditions (angle versus position on the pupil).
Cheers
Sim
  • · Replies 226 ·
17K
