Angular momentum and change in velocity
A turntable with a moment of inertia of 2.5 x 10^-2 kg m² spins at 33.3 rev/min when a 0.25 kg ball of putty is dropped on it, affecting its angular speed. The initial attempt to calculate the new angular speed using the equation Iω = (I + mr)ω(final) resulted in an incorrect answer of 27 rev/min, while the correct answer is 24 rev/min. The error was identified as a misunderstanding of the units involved, specifically that mr does not have the same units as moment of inertia (I). Proper application of angular momentum conservation principles is crucial for accurate calculations in such scenarios. Understanding the relationship between moment of inertia and angular velocity is essential for solving similar physics problems.
physgrl
A turntable has a moment of inertia of 2.5 x 10-2 kg m2 and spins freely at 33.3 rev/min. A 0.25 kg ball of putty is dropped vertically on the turntable at a point 0.20 m from the center. What is the new angular speed of the system?
a. 41 rev/min
b. 24 rev/min
c. 33 rev/min
d. 27 rev/min
L=Iω
p=mv
L=r*p
i tried to do Iω=(I+mr)ω(final)
i got 27 rev/min
the real answer is supposed to be 24rev/min according to the answer key
a. 41 rev/min
b. 24 rev/min
c. 33 rev/min
d. 27 rev/min
L=Iω
p=mv
L=r*p
i got 27 rev/min
Can you show the details of your calculation? We can't tell you what you did wrong if you don't show us your work!
"i tried to do Iω=(I+mr)ω(final)"
Careful, mr does not have same units as I.
Yeah that was my error thanks!
  • · Replies 17 ·
  • · Replies 18 ·
