Angular momentum and eccentricities question?
The discussion revolves around an asteroid in a circular orbit around the sun that splits into two fragments, each moving at different speeds. The original orbital speed is calculated as 2pi/(root3) AU per year, and the angular momentum per unit mass for the original asteroid and the fragments needs to be determined. The relationship between angular momentum and the semi-major axis and eccentricity of the orbit is established through the formula l = 2pi[a(1-e^2)]^0.5. Participants seek assistance in calculating the angular momentum, eccentricities of the new orbits, and the orbital periods of the original asteroid and the fragments. The thread highlights the complexities of orbital mechanics and the need for clarity in calculations.
magicuniverse
An asteroid is on a circular orbit around the sun with an orbital radius of 3AU. It splits into two fragments, which initially move aparty along the direction of the original orbit. One fragment has a speed of 0.65 of the original speed, the other has a speed of 1.35 times the original speed.
Original Orbital speed is 2pi/(root3) AU per year.
1) Calculate the angular momentum per unit mass l, of the original asteroid and of each of the two fragments in units of AU^2 per year.
In these units l can be related to the semi-major axis a i (in AU) and eccentricity e of the orbit by the formula l = 2pi[a(1-e^2)]^0.5
2) Calculate the eccentricities of the two new orbits.
3) Calculate the orbital periods of the original astroid and the two fragments (in years).
I am very stuck on this and any assistance would be really be appretiated.
  • · Replies 54 ·
  • · Replies 18 ·
