How Is Angular Momentum Calculated for a Gear Mechanism with a Spinning Motor?
Angular momentum for a gear mechanism with a spinning motor can be calculated using the equation M = w x I, where M is the angular momentum, w is the angular velocity, and I is the moment of inertia. The moment of inertia for the motor is simplified to I = m/2 * (r1^2 + (2*r1 + 2*r2)^2), leading to a calculated torque of 0.0635387 Nm. However, this value differs significantly from the torque calculated using the force and radius of the small gear, which yields 0.24525 Nm. The discussion highlights the necessity of accounting for friction and the continuous power supply required to maintain motor operation, emphasizing the relationship between torque, power, and angular acceleration. Understanding these calculations is crucial for accurately modeling the gear mechanism's performance.
risecolt
In the image showed in the link below I've illustrated a mechanism in which a small gear rotates about a large gear when the motor is spinning. The large gear is rigid and both of the gears are masless, except for the motor. The small gear has a radius of 25mm and the large gear has a radius of 45mm. I need to calculate what angular momentum (torque) is required when the mass of the motor and the angular velocity is known. I have eliminated one degree of freedom, the gears are held in place from getting off.
I'm using the following equation:
M = w x I (angular velocity x moment of inertia).
By simplifying the shape of the motor into a cylinder:
The motor weighs 1 kg and the angular speed is 60 RPM (2pi rad/second).
M = (2pi) * 1/2 * (0.025^2 + (2*0.025 + 2*0.045)^2)) = 0.0635387 Nm
But when I try to compare this with a more classic example:
M = F x r = 1kg*9.81m/s^2 * 0.025 m (radius of the small gear) = 0.24525.
These two values are significantly different.
Which one of these calculations are correct?
http://cognitivenetwork.yolasite.com/resources/Gear.png
Diagram for moment of inertia:
http://www.caddisegni.com/upload/calcoli/1-2.jpg
I realize I've made a small mistake.
So if I once have calculated desired angular momentum, I define torque as the rate of change of angular momentum.
So if I want the angular momentum to occur within 1 second, I can set up the equation:
torque / second = angular momentum. And once the speed has been achieved, there is no more torque.
So my next problem should be: What should the rate of change of angular momentum be, in order to overcome the friction preventing the motor from spinning? In other words, if the angular velocity is too low, the motor will stop. How do I go about to do this?
Sorry, but that's not true.. You always have to supply power (and hence torque) to overcome the friction.
Hi risecolt,
I don't think you need to go too deep into the physics of it. The power rating of the motor is enough. If the motor has rating P and the small gear is spinning with an angular velocity ω_{1}, the torque on the small gear is τ_{1} = P / ω_{1} . So, considering the gear ratio, the angular velocity of larger gear is ω_{2} = ω_{1} * d_{1} / d_{2}. So the torque on this gear will be τ_{2} = P / ω_{2}
Hope it helps :smile:
I agree. But I am thinking within a certain timeframe, and ideal system.
But we both know what we mean.
sci-phy said:
Hi risecolt,
That's a bit of a problem. Because the large gear doesn't spin. It is rigid.
Only the small gear rotate. So the small gear has to do all the work. Rotate itself, and translate itself about the axis of the large gear. As a bachelor degree student I must include as much physics as possible. But perhaps you can tell me the relationship between this equation and the previous? How about:
Torque = power / angular velocity = moment of inertia * angular acceleration?
My idea is that I want to use immerse Whitetail Antlers in a fishtank to measure their volumetric displacement (the Boone and Crockett system is the current record measurement standard to place in a juxtaposition with) I would use some sight glass plumbed into the side of the tank to get the change in height so that I can multiply by the tank cross-section. Simple Idea. But... Is there a simple mechanical way to amplify the height in the sight glass to increase measurement precision...
  • · Replies 42 ·
14K
  • · Replies 18 ·
