Angular Momentum Horizontal Metallic Bob
2 replies · 5K views · last reply
RivalDestiny
A small metallic bob is suspended from the
ceiling by a thread of negligible mass. The
ball is then set in motion in a horizontal circle
so that the thread describes a cone. Calculate
the magnitude of the angular momentum of the
bob about a vertical axisthrough the supporting point.
angle: 29
string length: 2.4 m
mass: 9 kg
L= r x mv
mass is given in the problem
radius can be found by:
(string length) * sin29 = r
I don't know how to find the velocity...do we first have to find the angular velocity and convert that over to linear velocity?
You have to draw a force diagram on the bob. It has a force of mg pointing down. There is a tension force T directed along the string. The vertical components of those two forces must cancel. That leaves you with a horizontal component of T pointing towards the center of the circle it's rotating in. Using F=ma that you can find the acceleration of bob towards the center of the circle. Equate that to the acceleration you produced by the circular motion.
alright, so I found the centripetal acceleration. Would I equate that to:
a=v^2/r?
r being the (L)*sin29..
then that would be v?
