Angular momentum of a particle system
The discussion revolves around calculating the total angular momentum of a particle system about the origin, using the equation L = r X p. The initial attempt at the solution yielded an incorrect total angular momentum of 4k due to an error in the third position vector. A participant pointed out that the correct third r vector should be <1.2i, -2j> instead of <1.0i, -2j>. After correcting this mistake, the original poster was able to arrive at the correct answer. The importance of accurately identifying position vectors in angular momentum calculations is emphasized.
jhu2011
Calculate the total angular momentum of the system of particles pictured in Figure P.10 about the origin at 0. Figure is at www.webassign.net/reese1/p10-10.gif.
L = r X p
p = mv
Since you are taking a vector product, there is no i or j component to the angular momentum, meaning there will just be k perpendicular to the plane. I read somewhere that when doing a system of particles, you should take the angular momentum of each separate particle and then add it up. However, when I do this I don't get the right answer... Using L = r X p:
For 1st 3m: -4i + 2j X -3i = 6k
For 1st 2m: 1i + 2j X 2i = -4k
For 2nd 2m: 1i -2j X 2j = 2k
And 6 - 4 + 2 = 4k, which is NOT the right answer. I don't know what I've done wrong...
L = r X p
p = mv
Welcome to PF.
Your 3rd r vector should be <1.2i, -2j> shouldn't it?
LowlyPion said:
Welcome to PF.
Indeed it should be. That 1.20 is so close to the 1.00! I got the correct answer now. Thanks a lot!
15K
  • · Replies 45 ·
  • · Replies 18 ·
  • · Replies 19 ·
