Angular Momentum of a system of particles relative to another point
The discussion focuses on calculating the total angular momentum of a system of two particles about the z-axis relative to two different points, A and B. Particle 1 has a mass of 23 kg and moves at 34 m/s, while Particle 2 has a mass of 64 kg and moves at -43 m/s. The correct angular momentum for point A is 25610 kgm²/s, while for point B, the angular momentum must be negative, resulting in -43340 kgm²/s. The key takeaway is that the direction of angular momentum must be considered when calculating for different reference points.
  • Understanding of angular momentum calculations
  • Familiarity with vector cross products
  • Knowledge of particle motion and mass
  • Basic principles of physics related to momentum
  • Study the concept of angular momentum in multi-particle systems
  • Learn about vector cross product calculations in physics
  • Explore the effects of reference points on angular momentum
  • Review the principles of conservation of angular momentum
This discussion is beneficial for physics students, educators, and anyone interested in understanding angular momentum in systems of particles, particularly in relation to different reference points.
DarkerStorm
Two particles move in opposite directions along a straight line. Particle 1 of mass m1 = 23 kg at x1 = 16 m moves with a speed v1 = 34 m/s (to the right), while the particle 2 of mass m2 = 64 kg at x2 = −25 m moves with a speed v2 = −43 m/s (to the left). Given: Counter-clockwise is the positive angular direction.
1)What is the total angular momentum of the system about the z-axis relative to point A along y-axis if d1 = 13 m? Answer in units of kgm2/s.
2) What is the total angular momentum of the system about the z-axis relative to point B along y-axis if d2 = 22 m? Answer in units of kgm2/s.
m1 = 23
Position1 = {16 i, 0 j, 0 k}
v1 = {34 i, 0 j, 0 k}
m2 = 64
Pos2 = {-25 i , 0 j, 0 k}
v2 = {-43 i, 0 j, 0 k}
d1 = {0 i, -13 j, 0 k}
d2 = {0 i, 22 j, 0 k}
L = Position [tex]\times[/tex] m v
I got number 1 correct, and number 2 should be the same. however just changing d1 to d2 does not give the correct answer.
1)
{16, 0 , 0} + {0, -13, 0} = {16, -13, 0}
{-25 , 0, 0}+ {0, -13, 0} = {-25, -13, 0}
{16, -13, 0} [tex]\times[/tex] (23 {34 , 0 , 0 }) +
{-25, -13, 0} [tex]\times[/tex] (64 {-43 , 0 , 0 }) = {0, 0, -25610} = 25610 k
2) should be the same but I get {0, 0, 43340} which is incorrect
Welcome to PF!
Hi DarkerStorm! Welcome to PF! :smile:
DarkerStorm said:
1)
Looks ok to me (opposite sign to 1), of course). :confused:
(btw, you could have omitted the {16, 0 , 0} and {-25, 0 , 0} :wink:)
hmm … you could try 43440, in case someone hit the wrong key. :redface:
Thanks the problem was that number 2 have to be negative.
  • · Replies 45 ·
