jimmysnyder said:
Are you reading this as "When an owner leaves their own tiger alone"?
It's an unclear question-- there are LOTS of holes. But I was reading it as:
"when an owner is separated from their tiger, the tiger will destroy any other owners or tigers that are with them."
If read as "when a tiger is left alone", then the "eat everything around it (tigers or humans)" becomes meaningless. Further, if read as "when a tiger is left without any owners around", then the "humans" becomes meaningless.
For the record, I'm interpreting the problem as:
There are 3 tigers, each with its own owner. The 3 tigers and 3 owners must cross a lake using only a particular boat. All of the tigers and owners are presently on the same side of the lake. The boat they must use is capable of carrying a maximum of 2 occupants. To be used, the boat must have at least one human present, or a single particular tiger whose identity is unknown. The two remaining tigers cannot use the boat individually or together. If a tiger is separated from its owner at any time, the tiger will consume all owners and tigers that are with it, meaning on its side of the lake or within the boat itself during the journey.
How are all 6 individuals able to cross the river such that they will all be on the opposite side at the same time, without any tigers or owners being consumed?
As with so many teasers that are posted here, this one is poorly worded.
- In the wording, it states "the boat can support a tiger and its owner, or 2 owners". So, according to the problem, single individuals cannot use the boat, the boat MUST be used by two individuals, and one of them MUST be a human. You could assume that a single person and/or tiger could use the boat, but if you do so, there's no reason to assume that all 6 couldn't use the boat at the same time.
- It says "when an owner leaves a tiger alone, the tiger will eat everything around it (tigers or humans)." Technically, this means that the tiger will NEVER eat anything around it, because if it's ever alone, there will be nothing to eat. Hence, any combination is fine.
- It never states that they must use the boat to cross. They could just walk around the lake. Or swim across. Or whatever.
Anyway, there are seemingly plenty of reasons why the given problem isn't possible, or why it IS possible using an unintentional interpretation.
DaveE
