Another Circular motion Question
6 replies · 2K views
steejk
A smooth wire forms a circular hoop of radius 1m. It is fixed in a vertical plane. Two beads, A and B, of masses m and 2m respectively, are threaded onto the wire. The coefficient of restitution between the beads is 0.5. Bead B rests at the bottom of the hoop. Bead A is projected from the topmost point with speed u, and subsequently collides with B.
Q. Show that Bead A is brought to rest by the collision.
My working so far:
Using the energy change of GPE --> KE
GPE = 2mg = 0.5mv^2
Increase in velocity is therefore 2sqrt(g)
At the point A collides with B its velocity is therefore u + 2sqrt(g)
Using conservation of momentum,
u + 2sqrt(g) = 2x + y (where x is the speed of B and y is speed of A after collision)
Using Newton's law of restituiton:
0.5 = (2x-y)/(u + 2sqrt(g))
And this is where I get stuck :( ...
GPE = 2mg = 0.5mv^2
Redo the algebra 2[itex]\sqrt{g}[/itex] is not the increase in velocity.
Remember, momentum is mass * velocity. So, on the left should be m*(u + increase in velocity). The right side also is missing the masses of the beads.
Lastly, the equation for the coefficient of restitution deals with initial and final velocities, not, momentum.
Any clues on where I'm going wrong..?
The masses cancel in the momentum equation I think. Would the initial velocity then not be u + increase. I did the final velocity wrong, is it just x - y?
You should calculate the total kinetic energy of bead A immediately before impact in order to determine its velocity. The change in velocity is not 2sqrt(g).
I suggest that you create another symbol to represent the impact velocity of bead A, say v, and leave it that way until the end when you may (or may not :wink:) need it expanded into its full form.
So, calling the initial speed of bead A v, the conservation of momentum gives you:
m*v = m*v1 + 2m*v2
where v1 is the speed of bead A after collision, and v2 is the speed of bead B. Clearly you can cancel the m's from that expression. Now write your Restitution Law in terms of v1 and v2 and see how things progress.
m*v = m*v1 + 2m*v2
Okay, so from the total KE at bottom v (speed of A before collision)
v^2 = u^2 + 4g
And from restitution,
0.5v = v2 - v1
Do I subst. v into this then?
use the equation gneill gave:
m*v = m*v1 + 2m*v2
And yes, the m's cancel, I didnt see that you did that, sorry. Anyway use that equation and
0.5v = v2 - v1
Solve for v1, the final velocity of bead A. Pretend v is known :wink: and just run through the algebra, you can solve one equation for v2 and substitute it into the other equation.
Got it :) Thanks wbandersonjr and gneill
