What is the final speed and direction of the first puck after collision?
  • Thread starter Thread starter physics(L)10
    Momentum
The discussion focuses on calculating the final speed and direction of a hockey puck after a collision, involving a 0.5 kg puck moving at 2 m/s colliding with a 1 kg puck. The final speed of the first puck is determined to be 1.25 m/s, while the direction is calculated based on the momentum conservation principles. Participants utilized equations for momentum (p=mv) and addressed both x and y components separately to arrive at the solution.
  • Understanding of momentum conservation principles
  • Familiarity with vector components in physics
  • Knowledge of trigonometric functions (sine and cosine)
  • Ability to solve linear equations
  • Study the conservation of momentum in two dimensions
  • Learn how to resolve vectors into components
  • Explore collision types: elastic vs. inelastic collisions
  • Practice problems involving momentum and angles
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators looking for examples of collision problems in a classroom setting.
physics(L)10
A .5kg hockey puck moving at 2 m/sec strikes another puck with a mass of 1kg. The puck then travels at an angle of 60 degrees with a speed of .75m/sec with respect to the motion of the original puck.
a) What is the final speed of the first puck?
b) What is the final direction of the first puck?
m1=.5kg
m2=1kg
v1=?
v2=.75 m/sec
p=mv
ΔP1 + ΔP2 = (F1 + F2)(Δt)
m1u1 = (m1+m2)v cos60
m2u2 = (m1+m2)v sin60
This is all I can get. I think I'm right so far lol. I need help badly! This momentum stuff is killing me.
right, so the initial x-direction momentum is m1u1, the initial y-direction momentum is?
But they did not say the masses stick together, so you cannot assume that. Instead assume mass 1's final velocity is v1 (vx1 and vy1 components) and mass 2's is v2, they said v2 is 0.75 m/s at 60°.
So what is the final x-direction momentum and y-direction momentum?
Well I've been working on this question and this is what I came up with. Please take the time to read it and give your input. Thank you very much :):)
m1=.5kg
m2=1kg
v1I=2 m/sec
v2I=0 m/sec
v2F=.75 m/sec
P=mvcos
=(1)(.75)
=.75 kgm/sec
PTotal=m1v1I+m2v2I
PTotal=m1v1F+m2v2F
PTotal=(m1+m2)v
=(.5)(1)(2)
=1kgm/sec
PTotal=m1vF1+m2vF2
1=(.5)vF1 + (1)cos30
1=vF1 + 0.866
.134=vF1 = final speed
physics(L)10 said:
P=mvcos
=(1)(.75)
=.75 kgm/sec
Why did you neglect the angle?
physics(L)10 said:
PTotal=(m1+m2)v
=(.5)(1)(2)
=1kgm/sec
Your answer is correct, but why do you keep assuming that the masses stick together?
physics(L)10 said:
PTotal=m1vF1+m2vF2
1=vF1 + 0.866
You have another component to deal with, the vertical component.
Would the angle be 90 degrees which would make the whole thing 0?
I just don't know how to do it singly lol.
Alright I'll work on this
The question said at 60°
Just write it out as single components
m1u1+m2u2=m1v1+m2v2
Remember consider the x and y directions separately at first.
ok i think i got it, hopefully lol:
p=mv
m1u1+m2u2=m1v1+m2v2cos60
(.5)(2)+(1)(0)=.5v1+(1)(.75)cos60
1=.5v1+.375
.625=.5v1
1.25=v1
b) The final direction would just be forward because the value of the speed is positive. Or do you use a formula to find the direction. I'm guessing you use v2=u2+2as, but we don't know acceleration unless it's the gravitational acceleration.
Thank you for any help you give :D
p=mv
1=.5v1+.375
.625=.5v1
1.25=v1
This gives you the horizontal component.
Remember you need to apply conservation of momentum vertically as well.
When you get vx and vy for the puck, the direction is just the angle to the horizontal.
Would the vertical component be the same as the first equation except we would use sin60 instead of cos60?
Yes but your initial vertical momentum would be zero.
Alright I got it, thanks a lot :D
  • · Replies 35 ·
