Another successive dilution problem
  • Thread starter Thread starter Benzoate
    Dilution
The discussion focuses on calculating the concentration of HCl in a bottle after a series of dilutions and titrations. The initial concentration of NaOH is given as 0.08329 M, and the titration requires 43.91 mL of NaOH to reach the endpoint with 26.53 mL of diluted HCl. The calculation for the final concentration of HCl results in 0.00134 M, derived from the dilution factors and titration volumes. The normality of the final solution is questioned, with a proposed answer of 0.77 N. The discussion emphasizes the importance of understanding dilution and titration principles to determine the concentration accurately.
Benzoate
The concentration of HCl in a bottle was determined as follows:
* 4.00 mL of the acid were diluted to 150.00 mL
* 26.53 mL of the diluted acid were titrated with 0.08329-M NaOH
* 43.91 mL of the base were required to reach the end point
What is the HCl concentration in the bottle?
Possibly C(final)=C(initial)*(v(1)/v(2))*(v(3)/v(4))* ,...
C(initial)= .08329 M
For end Volume I assume that be V(4) and V(3) would be the titrated volume.
C(final)=.08329 M *(4 mL/150 mL)*(26.53 mL/43.91mL)= .00134 M
2HCl + 2NaOH - > 2NaCl +2H20
Valence factor of NaOH = 1
Valence factor of HCl = 1
Normality of NaOH = 0.08329N
Equivalents used = 0.08329 * 43.91 = 3.657meq
SO equivalents of HCl in 26.53ml(dil) = 3.657meq
Eq in 154 ml water diluted sol = ?(Get the result in meq)
Volume of sol, = 154ML
U have got the meq U have got the Vol.U can find concentration in Normality or Molarity.
Is the answer .77N right?
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
