Is there a vector proof for (u x (v+w)) . r = (u . w)(v . r) - (u . v)(w . r)?
  • Thread starter Thread starter Bipolarity
    Proof Vector
The discussion revolves around proving the vector identity (u x (v+w)) . r = (u . w)(v . r) - (u . v)(w . r). A participant has simplified the left-hand side to (r x u) . v + (r x u) . w but is unsure how to proceed. There is uncertainty about whether the proof can be completed using only vector identities without resorting to components. Another participant suggests that the original equation may contain a misprint and proposes an alternative identity to prove instead. The conversation highlights the challenges in vector proofs and the importance of clarity in mathematical statements.
Bipolarity
Show that (u \times (v+w))\cdot r = (u \cdot w)(v \cdot r) - (u \cdot v)(w \cdot r)
So far I have been able to simplify the LHS to:
(r \times u)\cdot v + (r \times u) \cdot w but don't know how to proceed from there.
In fact, I don't know if this problem is even solvable using only vector identities, i.e. without having to prove using components.
All help is appreciated!
BiP
Hi Bipolarity! :smile:
It's a misprint :rolleyes:
try (u \times (v \times w))\cdot r = (u \cdot w)(v \cdot r) - (u \cdot v)(w \cdot r) :wink:
Thanks tiny-tim!
BiP
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
