Answer to high-school question
  • Context: Undergrad
  • Thread starter Thread starter mzambani
The discussion revolves around a sequence involving mass and velocity in physics, specifically the expression m + mv + mv² + mv³ + ... and its potential meaning or implications. Participants explore the mathematical properties of the sequence, its physical significance, and the issues surrounding units of measurement.
  • One participant questions the meaning of the sequence m + mv + mv² + mv³ + ... in the context of conservation laws in physics.
  • Another participant points out that the units involved do not allow for summation, as adding different physical quantities (mass, momentum, energy) does not yield a meaningful result.
  • A later reply acknowledges the lack of physical meaning in the sequence but notes that it can be interpreted mathematically as a geometric series under certain conditions.
  • One participant rewrites the sequence in terms of an exponential series, suggesting a form m * e^v, but expresses uncertainty about the physical interpretation of e raised to the power of velocity.
  • Another participant highlights that exponents must be unitless, reiterating the issue with units in the proposed expressions.
Participants generally agree that the sequence lacks physical meaning due to unit inconsistencies, but there is a mathematical exploration of its properties. The discussion remains unresolved regarding any potential interpretations of the sequence in a physical context.
Limitations include unresolved issues regarding the interpretation of units in the context of the sequence and the assumptions made about the properties of mass and velocity.
mzambani
Hello,
When I was studying physics in high-school, I often wondered what would be the meaning of sequence below in physics...
m + mv + mv2 + mv3 + ...
This is equivalent to
[tex]\sum[/tex]mvn for n=0 to infinity
where m is mass, and v is velocity.
The though process was, that if mass (m) is conserved, momentum (mv) is conserved, and a form of energy (1/2 mv2) is conserved, then their sum probably should be conserved as well - resulting in above rudimentary sequence.
I never studied physics further, but I always wanted to see what this sequence - if any, would mean in physics. Can some one point me to it? Since velocity (v) is directional, I could never figure out how it can be summed in a sequence like this...
Mathematics news on Phys.org
Units don't allow summation. Adding kg to kg*m/s to J and so on doesn't make sense.
Thank you Borek. It is so obvious, and I did not see it...this sequence has no meaning in physics.
As a purely mathematical sum, it does have sense:
[tex]\sum mv^n= m \sum v^n[/tex]
is a "geometric series". If -1< v< 1, its sum is
[tex]\frac{m}{1- v}[/tex]
But yes, Borek is correct. If v has units of "distance/time" then the series, or even just "m+ mv+ mv^2" has impossible units.
I remember I re-wrote it into this form:
m + mv + 1/2 mv2 + 1/6 mv3 + ...
m + 1/1! mv + 1/2! mv2 + 1/3! mv3 + ...
m ( 1 + v/1! + v2/2! + v3/3! + ...)
which is equal to
mev (using exponential series)
But then I could never think of any meaning of ev..what could possibly be e to the power of "velocity"?
By taking it further...
m*ev = some constant (k)
then
ev = k/m
so
v = log(k/m)
where v is velocity and m is mass
There is an issue with units again. Exponents must be unitless.
HallsofIvy, Redbelly98 - thank you for taking time to answer my question. Yes, I realize there is issue with units. My curiosity is satisfied. Thanks.
  • · Replies 30 ·
  • · Replies 53 ·
