Ansys Maxwell simulation problem
8 replies · 7K views
ismail BAYSAL
I am using Ansys 18.2 Maxwell 2D to analyze a transformer by using transient and magnetostatic solvers. Normally the analyses were completed correctly and took time like a half an our . But right now the simulations are comleted suddenly(in few seccond) and there is no error no result and no solution. I mean, I guess the program not solve the simmulation but there is no error, Everything looks like correct. Is there anybody to help me to fix this situation.
Thank you...
Thank you...
Welcome to the PF.
Is it having trouble converging in the initial conditions? How can there be no error, no result and no solution? Can you post screenshots of what it used to look like and what is happening now?
These are from the latest analyze
There is no error or warning. The simmulation is completed in 3 or 4 second (Normally it takes about half an hour especially for transient solver
The following images from older simmulation (different simmulation). It was run correctly, I obtained all results correctly. Also this analyze is not working, Same situation is appeared when I reanalyzed
I assume you had it working and then it stopped working?
If that is the case then why not revert to a functioning model, and then compare all model inputs, excitation, analysis setup, mesh etc to see where the dif lies?
In my case, the problem has occurred straight away.
However, i found out that there were an error at the end of the installation (see picture below) :
The problem only occurs with Maxwell. I tried to solve a simple circuit with simplorer and it worked just fine.
deeps_ika said:
@ ilCapitano can you tell me how did you solve the above problem at the end of installation?
Welcome to PhysicsForums. :smile:
It looks like @ilCapitano has not been back here for a couple of years, so you may want to start your own thread with your question.
