Antenna Design Books: 60Hz to 100KHz Textbooks/Ref Material
This discussion focuses on the need for textbooks and reference materials specifically for designing loop antennas that operate within the long wavelength spectrum of 60Hz to 100KHz. The user highlights the complexity of the design process, which extends beyond Faraday's law, and emphasizes the significant physical dimensions required for effective antenna construction, such as a square loop measuring 2840 feet at 100 KHz. Additionally, a resource for ferrite antennas capable of receiving frequencies from 20 KHz to 100 KHz is provided, priced at approximately 156 euros (US$217).
  • Understanding of electromagnetic theory, particularly Faraday's law
  • Knowledge of antenna design principles
  • Familiarity with loop antenna configurations
  • Basic skills in RF engineering and measurements
  • Research "Loop Antenna Design Techniques" for detailed methodologies
  • Explore "Ferrite Antenna Applications" for insights on ferrite materials
  • Study "Antenna Height and Ground Effects" for optimal placement strategies
  • Investigate "Long Wavelength Transmission Challenges" for practical considerations
Electrical engineers, RF designers, amateur radio enthusiasts, and anyone involved in antenna design and construction for low-frequency applications.
dmorris619
I am looking for textbooks or reference material that will help my design a loop antenna to operate in the long wavelength spectrum(60Hz to 100KHz to be exact). I understand there is more to consider than just Faraday's law and am looking for a book that can help step me through the process of design.
If you want just one frequency, designing it is no problem.
For example, at 100 KHz, the sides of a square loop would be 2840 ft long. That is 865 meters or over half a mile.
Building it would be a problem as it really needs to be about that same distance above the ground.
I found this site:
http://www.amateur-radio-antenna.com/magneticantennas/magneticferriteantenna1/ferriterodantennaslfm20100.php
They have ferrite antennas for receive that work from 20 KHz to 100 KHz. About 156 euros US$217. 340mm (about 1 foot) long.
  • · Replies 44 ·
9K
