Apparent Power, Real Power and Reactive Power
The discussion focuses on calculating current, apparent power, real power, and reactive power in an AC circuit with a voltage source defined as v(t) = 169.7sin200t V, a resistance of 10 ohms, an inductance of 10 mH, and a capacitance of 500 µF. The conversion from peak voltage to RMS voltage is clarified as v = 169.7/sqrt(2), which is essential for power calculations in AC circuits. The impedance of the circuit components is expressed using complex numbers, and the power factor is determined by dividing real power by apparent power. Understanding these concepts is crucial for electrical engineers and technicians working with AC circuits.
  • Understanding of AC circuit theory
  • Familiarity with complex numbers and phasors
  • Knowledge of impedance calculations for resistors, inductors, and capacitors
  • Ability to perform RMS voltage conversions
  • Study the calculation of impedance in AC circuits using jwL and 1/jwC
  • Learn about power factor and its significance in electrical engineering
  • Explore the concept of complex power and its components: real, reactive, and apparent power
  • Investigate the use of phasor diagrams for visualizing AC circuit analysis
Electrical engineers, students studying AC circuit analysis, and technicians involved in power systems who need to understand the relationships between voltage, current, and power in AC circuits.
fatmoe
A voltage source of v(t) = 169.7sin200t V is connected across a series combination of a resistance of 10 ohm, an inductance of 10mH, and a capacitance of 500 uF. Determine the current in the circuit, the apparent power, the real power, and the reactive power supplied by the source. What is the power factor of the circuit.
I am having problems with this questions, as I don't know how to get the voltage since no time is given, and without the voltage, none of the equations are going to be any good.. Can someone point me in the right direction on how to get start with this question?
Well, I figured out how to calculate the voltage = v = 169.7/sqr(2).. But I don't understand where the sqrt(2) comes from in this formula?
That's the conversion from peak to RMS for the magnitude of the voltage source. If you're dealing with power in an AC circuit you almost always want to be working with RMS values.
If you are proficient in vectors it should be doable for you.
impedance of cap: 1/jwC
impedance of inductor: jwL
w=200 in this case. (omega=200)
J simply equals 1<90
Add up your three impedances.
10 + 1/jwC + jwL
10+ (1/wC)<-90 + (wL)<90
This will give you one vector at 0 degrees, one at -90 degrees and one at 90 degrees.
Add them together and you will have one vector with an angle. Now divide your RMS voltage by this Vector with the angle. You now have the current...also a vector with an angle.
Now multiply your RMS voltage by your current. This will give you your apparent power...also with an angle.
Current and power should be complex conjugates.
Now find the x and y-axis of your apparent power from the angle. The x-axis is your real power and the y-axis is your reactive power.
To find power factor, divide real power by apparent power.
Notice how the "time" you mention above was not needed to find any of the answers.
It takes new electrical guys quite a while to grasp all these concepts together. So if you don't get it the first time, or even 10th time, understandable.
  • · Replies 16 ·
