Applcation of the inverse function theorem
The discussion revolves around the application of the inverse function theorem to a function defined on Rn. The original poster is tasked with showing the existence of neighborhoods and a diffeomorphism related to a function f that satisfies certain conditions at the origin.
  • Participants discuss the need to construct a suitable function F that extends f to apply the inverse function theorem. There is uncertainty about how to define F and ensure its derivative is invertible.
  • One participant suggests a specific form for F and checks the conditions for invertibility of its derivative.
  • Questions arise regarding the proper formulation of the relationship between g and f, particularly whether g should be the inverse of F or if another relationship holds.
The discussion is active, with participants exploring different formulations and questioning the implications of their choices. Some guidance has been offered regarding the construction of F and its properties, but clarity on the relationship between g and f remains a point of contention.
Participants are navigating the constraints of the problem, particularly the requirement that f is defined on Rn and the implications for the application of the inverse function theorem. There is also a focus on ensuring that the derivative of the constructed function F is invertible at the origin.
Kate2010
Let f [tex]\in[/tex] C1(Rn) be a function such that f(0) = 0 and [tex]\delta[/tex]1f(0) is nonzero. ([tex]\delta[/tex]1 means partial derivative with respect to x1)
Show that there exist neighbourhoods U and V of x=0[tex]\in[/tex] Rn and a diffeomorphism g:U->V such that f(g(x)) = x1 for all x = (x1,...,xn) [tex]\in[/tex] U.
Inverse function theorem:
Let S[tex]\subseteq[/tex]Rn be open, f [tex]\in[/tex]C1(S,Rn) and x0[tex]\in[/tex]S. If Df(x0) is invertible then there exists an open neighbourhood U of x0 such that f(U) is open and f: U -> f(U) is a diffeomorphism. Also Df-1(f(x0)) = (D(f(x0))-1.
I have a hint that says to apply the inverse function theorem to some function F:Rn -> Rn.
But, I really have no idea what this should be. I think it should involve f but I'm not sure how. Also I noticed g(x) = f-1(x1) if f-1 exists but then I'm not sure this makes sense as f is defined on Rn not R. So any help with finding this F would be great!
Hi Kate2010! :smile:
You're correct that you can't apply the theorem directly to [itex]f:\mathbb{R}^n\rightarrow \mathbb{R}[/itex]. But maybe you can extend f so that the codomain is good. I mean, your function F should be of the form
[tex]F(x_1,...,x_n)=(f(x_1,...,x_n),?(x_1,...,x_n),...,?(x_1,...,x_n))[/tex]
where ? are the functions you still need to find. Don't look too far, the ?-functions are very easy (but make sure that the condition DF(0) is invertible).
You should use [ itex] and [ /itex] to make LaTeX. The [ tex]-brackets automatically start a new line.
Ok, thanks!
How about F(x1,...,xn) = (f(x1,...,xn), x2,..., xn)? Then DF(0) is a matrix that is upper triangular, with 1s on the diagonal except for the first diagonal which we know is non-zero, then the det is non-zero, so it is invertible. Also we know that F(0,...,0) = (0,...,0). So by the inverse function theorem F is a diffeomorphism.
But I'm still not sure about how this helps me with g? If we look at the first component, the inverse of F will map f(x1,...,xn) to x1, so I can kind of see that it is true, but I don't know how to write this properly.
What if we just choose g=F-1, won't that work?
But then doesn't that give g(f(x)) = x1 instead of f(g(x)) = x1?
  • · Replies 31 ·
