Thank you so much for all the helpful replies. I should have given a bit more info but I think it will be alright. The fan is a universal permanent magnet radiator fan, basically. It has a 12 volt 80 watt rating on it, so based on I =P/E, the current draw should be just under 7 amps. When I hook up the 50 watt panel, the motor only runs at about two thirds of the speed than when it is hooked up to a car battery. Voltage across pos. and neg. at the motor only reads about 7 volts and amps measured in line shows about 3 amps, so I am assuming because the panel has such a low wattage output, the motor should not be affected. It definitely is not heating up, even running all day which was also worrisome because I am sure these type of motors are not meant for continuous duty. I really do appreciate all of the help and thank you so much.
