Applying Newtons laws ( Equilibrium)
The problem involves a loudspeaker suspended by two cables, requiring the determination of the tension in the cables while considering the forces acting on the system. The subject area relates to Newton's laws and equilibrium in physics.
  • Participants discuss the weight of the loudspeaker and the geometry of the setup, including the angles formed by the cables. There is an exploration of how to resolve the forces into their components and the implications of having two cables.
Some participants have provided guidance on resolving the forces and calculating the angles involved. There is an acknowledgment of differing levels of understanding regarding the vector components of the forces. Multiple interpretations of the problem setup are being explored.
There is a mention of the original poster's uncertainty about the equations to use and the teacher's effectiveness in conveying the material. The discussion reflects a collaborative effort to clarify concepts and assumptions related to the problem.
sktgurl930
A 26.21 kg loudspeaker is suspended 1.15 m below the ceiling by two 3.91-m-long cables that angle outward at equal angles. What is the tension in the cables?
I have no idea
well i know that i have the weight which is 26.21 kg and how far its is from the ceiling
and that I am trying to find N but i just don't kno wat equation to use but once i find N would i have to divide by 2 since there's 2 cables??
I have no idea
Figure what angles the cables make holding the speaker first.
Then draw your vector diagram of the tensions and resolve the x and y components. You know the X direction components must add to 0 and the Y components muust add to the 26.21 kg.
ok so would the angles be 17 since they are equal angles??
and i got 17 by making a right triangle with 3.91 being the hypotenuse, and since the speaker is 1.15m away from the ceiling making that one of the sides of the triangle with the right angle.
im i right?? or totally off
im not going to lie I am teacher isn't very good at teaching
so i have no idea wat ur talkin about with x and y
please don't hate me
That would be correct. It is 17 degrees. I get 17.1, but that's close enough.
So now you know that 1/2 the weight 26.21kg * 9.8 m/s2 is carried by the vertical component of the tension in the cable. As you noted each cable will carry 1/2.
If that vertical force must be carried in the cable then the tension must be = 1/2 weight/Sine(17).
(Answer in Newtons)
That treats the Tension as having 2 force components. One vertically (you found) and the other horizontally (given by 26.21*(Cos(17)). When added together as you would add vectors, that adds to the answer you just found. Since the speaker is not in motion, you know that the horizontal components are equal and opposite.
Another way to find the answer would be to recognize that
9.8*26.21*(1/2)/1.15 = Total Tension/3.91
This would be because the definition of Sine is Vertical over hypotenuse and those forces must remain in the same ratio, so ... you can exploit that as the quick way to calculate it as like ratios.
thank u and i wish u were my teacher dude ur a life saver!
  • · Replies 42 ·
  • · Replies 17 ·
