Approximating unsolvable recursion relations
  • Context: Graduate
  • Thread starter Thread starter Hoplite
    Recursion Relations
The discussion centers on approximating an unsolvable recursion relation defined by the equation \(\frac{(k+4)!}{k!}\xi_{k+4} + K_1 (k+2)(k+1)\xi_{k+2} + [K_2 k(k-1) + K_3] \xi_{k} + K_4 \xi_{k-2} = 0\). The constants \(K_1, K_2, K_3,\) and \(K_4\) are specified, and the constraints \(\sum_{k_{even}} \xi_{k} = \sum_{k_{odd}} \xi_k = 1\) and \(\sum_{k_{even}} k \xi_{k} = \sum_{k_{odd}} k \xi_k = 0\) are provided. The goal is to produce an approximation for the sum \(S(z) = \sum_{k=0}^\infty \xi_k z^k\) using techniques such as the z-transform, leading to the equation \(S'''' + (a + bx^2)S'' + (c + dx^2)S = e_5x^5 + \dotsb + e_0\).
  • Understanding of recursion relations and their properties.
  • Familiarity with z-transforms and their applications in solving differential equations.
  • Knowledge of series convergence and entire functions.
  • Basic concepts of ordinary differential equations (ODEs) and boundary conditions.
  • Research methods for solving complex recursion relations.
  • Study the application of z-transforms in approximating series solutions.
  • Explore the properties of entire functions and their convergence behavior.
  • Learn about boundary value problems in the context of ordinary differential equations.
Mathematicians, theoretical physicists, and anyone involved in advanced numerical analysis or solving complex recursion relations and differential equations.
Hoplite
I have a complicated recursion replation, which I'm sure is unsolvable. (By "unsolvable" I mean that there is no closed form solution expressing \xi_1, \xi_2, \xi_3, etc. in terms of \xi_0.) It goes
\frac{(k+4)!}{k!}\xi_{k+4} +K_1 (k+2)(k+1)\xi_{k+2}+ [ K_2 k(k-1) +K_3] \xi_{k} +K_4 \xi_{k-2} =0,
for k=0,1,2,3..., where K_1, K_2, K_3 and K_4 are constants. However, what I do know about the \xi_k's is that
\sum_{k_{even}} \xi_{k}=\sum_{k_{odd}} \xi_k=1,
and that
\sum_{k_{even}}k \xi_{k}=\sum_{k_{odd}}k \xi_k=0.
\xi_k is also zero for all k<0. What I want to do is produce an approximation of the sum for
S(z) =\sum_{k=0}^\infty \xi_k z^k.
Does anyone have any idea how to do this?
If I remember correctly that type of recursion relation is solvable. Somehow you take differences of consecutive equations until you have
\sum_1^N a_i\xi_{k+i}=0
and then you use a geometric series as the trial solution. Not sure if the degree of that polynomial becomes too large.
But maybe the contraints help.
What do you mean? Isn't S=2 then?
Oops, sorry. I had the wrong equation for S. I've fixed it now.
Using something which I think is called z-transform you get
S''''+(a+bx^2)S''+(c+dx^2)S=e_5x^5+\dotsb+e_0
I guess that's your initial problem in reverse :)
Anyone knows how to solve this? I've found
http://eqworld.ipmnet.ru/en/solutions/ode/ode0406.pdf
but that only works for a special contraints on the parameters.
This series will converge really quickly - this is definitely an entire function. It's probably just as good to deal with the recursive relation. Even if you had a closed form, it wouldn't help you to evaluate the function.
Do you need a closed form, or do you just think you need it? For the purpose of it being a solution to an ODE, this is just as good.
That's correct. In fact my equation is
S''''+(a+bx^2)S''+(c+dx^2)S=0,
with some inhomogenious boundary conditions.
Sorry for messing around and confusing people :)
But maybe the special case from that webpage helps a bit :)
  • · Replies 36 ·
