Are cyanobacteria aerobic or anaerobic?
  • Thread starter Thread starter Erland
The discussion revolves around the metabolic characteristics of cyanobacteria, specifically whether they are aerobic or anaerobic organisms. Participants explore the implications of their metabolic processes, including photosynthesis, glycolysis, and the evolution of respiration mechanisms.
  • Some participants question how cyanobacteria could be aerobic if they were responsible for oxygenating the atmosphere through photosynthesis.
  • Others suggest that if cyanobacteria are anaerobic, their energy efficiency might be limited due to the absence of the Krebs cycle and electron transport chain.
  • One participant mentions that cyanobacteria do possess an electron transport chain, which is fundamental for energy production in many cellular organisms.
  • There is a discussion about the classification of cyanobacteria, with some arguing that not all cyanobacteria perform photosynthesis, leading to confusion over their definition.
  • Some participants propose that cyanobacteria may have initially used glycolysis and fermentation for ATP production before evolving aerobic respiration after oxygen became abundant.
  • Another viewpoint suggests that cyanobacteria could have maintained high internal oxygen levels from their own photosynthesis, allowing for aerobic respiration even before atmospheric oxygen was prevalent.
  • One participant notes that some cyanobacteria are heterotrophic and do not perform photosynthesis, indicating diversity in metabolic capabilities.
  • There is mention of the evolutionary history of cyanobacteria, including endosymbiosis and the transition from photosynthetic to non-photosynthetic forms.
Participants express multiple competing views regarding the metabolic nature of cyanobacteria, with no consensus reached on whether they are strictly aerobic or anaerobic, or the implications of their metabolic processes.
Participants highlight limitations in definitions and classifications of cyanobacteria, as well as unresolved questions about their evolutionary adaptations and metabolic pathways.
Erland
If they are aerobic, where did they get oxygen from, before cyanobacteria themselves filled the atmosphere with oxygen as a waste product of photosynthesis?
If they are anaerobic, then how can they use energy efficiently? Glycolysis alone gives little energy, and they don't have the Krebs cycle and the Electron transport chain. Do they use some other method?
Biology news on Phys.org
What research have you done so far? What have you found?
Well, I tried Google, looked up Wikipedia, made a short search here at PF, also Quora. I didn't find any clear answer. But I admit, I didn't search for hours.
Do you have any suggestion where one quickly can find a clear answer of the question?
"Whereas only the Oxyphotobacteria can perform photosynthesis, there are members from all three cyanobacterial classes that are capable of aerobic respiration."
From Soo et al.
Cyanobacteria do have an electron transport chain (see electron transport and photosynthesis in this wikipedia entry).
It is my understanding that an electron transport mechanism in the basis of metabolic power for almost all cellular organisms, most likely inherited from the last common cellular ancestor of life on earth.
The chemistry of the electron donors and acceptors, over evolutionary times or between different organisms, can vary depending upon the metabolism that has evolved. https://www.nature.com/scitable/content/the-redox-tower-of-microbial-metabolism-24272738.
If their environment is not under intensive use by other organisms they can get away with not being particularly efficient, since they are not really competing, just surviving.
Thanks for your replies Vagn and Billtre! Interesting links.
One thing makes med confused. According to the Wikipedia link cyanobacteria "are a phylum of bacteria that obtain their energy through photosynthesis", but the Science article quoted by Vagn, talks about three classes of cyanobacteria, of which only one, Oxyphotobacteria, can perform photosynthesis.
This seems contradictory to me. Is there no agreement of what a cyanobacterium is and whether it must be able to perform photosynthesis or not?
There are disease causing cyanobacteria, for example. They are heterotrophs (no photosynthesis).
Also the same membrane system for photosynthetic processing is also used for O2 respiration processes.
So:
1. they all started out using photosynthesis.
2. some evolved into other non-photosynthetic forms.
3. Through endosymbiosis a few ended up as plasmids in eurkaryotic cells (e.g. chromoplast, leucoplast) , somewhat like how mitochondria came to be . Because these are not free living they are no longer considered a species.
Species is a veil through which we filter the biological world, to try to make order out of a very messy situation. DNA has had a clarifying effect but the mess still remains.
Good question. Perhaps cyanobacteria were preadapted to be tolerant of oxygen but probably used glycolysis and fermentation as a source of ATP. After they filled the world with oxygen they then evolved aerobic respiration.
Well even before elemental oxygen was available in the atmosphere, there would still be relatively high concentrations of oxygen inside the Cyanobacteria from their own photosynthesis. So they could have aerobic respiration before then. Something I just read:
“An alternative suggestion [for the endosymbiosis with a cyanobacterium] is that the initial advantage of plastids may have simply been their uniquely useful metabolic end product, O2, as a boost to respiration in early mitochondria (Martin and Mu ̈ller 1998). The chemical benefit of O2 could, of course, have only been of value if the initial endo- symbiosis had taken place at a time in Earth’s history, or in an environment, where O2 was not freely available in sufficient amounts.”
Genomes of Stigonematalean Cyanobacteria (Subsection V) and the Evolution of Oxygenic Photosynthesis from Prokaryotes to Plastids, Dagan et al., 2012
Even if that isn’t actually the reason for the evolution of plastids, it shows that Cyanobacteria would produce enough oxygen in their cells to be a tiny aerobic environment.
So they filled the seas and air with a freshet of Oxygen and a tang of Alcohols, which then was a fuel and oxidizer source of life for some other bio-active critters.
33K
