- 10,488
- 1,638
DParlevliet said:I understand, but the result is simple.
GT is r = 6G.M/v2 and Newton r = G.M/v2. Where is 6 coming from? Is one of the variables 6 times smaller or larger?
It is often suggested that r is not the physical distance we know. If the Earth would be a black hole its Scharzschild radius would be 9 mm. Then what is the "real" radius here?
I don't understand where this formula came from. If we take the limit of large L in the formula I gave above, so that (L/c) >> (GM/c^2), we find that the term in the square root is essentially equal to L/c. Note that physically GM/c^2 is just the Schwarzschild radius. Then we can write that ##R = L^2 / GM##. This is the same as the Newtonian formula. In the limit of large R -> large L, we can say that there are no significant time dilation effects, so that we can replace ##d\phi / d\tau## with ##\omega##. Substituting in the definition of L, our formula reduces to ##R = R^4 \omega^2 / GM## . We can re-write this to solve for ##\omega## and we get ##\omega^2 = GM/R^3##.
The lowest possible value of L for a stable circular orbit is when ##\frac{L^2}{c^2} = 12 \left(\frac{GM}{c^2}\right)^2##, because the term in the square root must be positive for the formula to apply. Solving for R, the term in the square root is zero, and ##R = \left(\frac{L}{c}\right)^2 / \left(2GM/c^2\right)## To find the value of R at which this occurs, we substitute ##L^2/c^2 = 12 G^2 M^2 / c^4## and get ##R = 6GM / c^2##.
There are circular orbits inside this radius, but they are unstable. The smallest possible unstable orbit occurs when ##R = 3 \frac{GM}{c^2}##, which is the photon sphere. Inside this, no circular orbits exist at all.
The web-page gives the differential equation and a simulator for what happens for the orbit of a particle with a given L and a given initial radius, along with the "effective potential" diagram. The behavior isn't intuitive, but it follows from the differential equations of motion.
Perhaps the exposition in terms of L is less satisfying than one in terms of "velocity", but it's much easier to define. It would be possible to further expound on the nature of what we mean by "velocity", but that would take a lot of writing, and I'm not sure that it's not a digression from the topic as well as being a lot of work.
