johann1301
- 216
- 1
Are the Real numbers R a subset of the complex numbers C?
The discussion centers around whether the set of real numbers R can be considered a subset of the complex numbers C. Participants explore various definitions and structures of both sets, including their properties as fields and vector spaces.
Participants express differing views on whether R is a subset of C, with some supporting this notion and others advocating for a more nuanced understanding that emphasizes isomorphism and structural differences. The discussion remains unresolved, with multiple competing perspectives presented.
Participants note that the definitions of R and C can vary widely, which affects the conclusions drawn about their relationship. The discussion also touches on the implications of viewing C as a two-dimensional vector space versus a field, highlighting the complexity of these mathematical structures.
WWGD said:Each of C, R have different structure ; as sets, as fields, as metric spaces, etc. If you consider both as sets, then yes; R is a subset of C, it is the subset of the form {a+i.0: a is a Real number}. But there are relationships between the two other than this one.
haruspex said:As Halls and FactChecker point out, it's a lot stronger than merely being a subset in the set-theoretic sense. (In fact, in that sense, it's a matter of choice whether you consider it a subset, or even which subset!)
The point is that all the structure of C, as inherited by the subset we think of as R, is an exact match for the structure of R. The dyadic etc. operations all still work and produce the 'right' answers. In short, it is an isomorphism, which is as close as you can get to saying two independently defined mathematical entities are the 'same'.
homeomorphic, as it happens, I've just been arguing on another thread against thinking of C as being R2 with some multiplication rules. That's fine for a visualisation, but it can convey the impression that C is some sort of two dimensional vector space. This gets quite confusing when later you find C is a scalar field over which vector spaces can be defined.
johnqwertyful said:But C IS a 2 dimensional vector space over R. All field extensions are vector spaces over their base fields.
haruspex said:No, it induces a 2D vector space, but it is not the same as a 2D vector space. Part of the definition of C is the multiplication function *:CxC→C.
I fail to see why that would be confusing. C is naturally endowed with a real 2-dimensional Vector space structure, ans also with a field structure (thus a complex 1-dimensional vector space structure).
Therodre said:Hi,
Although i would not say that two isomorphic structure are as close as it gets to being the same, i'd say that what is closest is "uniquely isomorphic" (which is the case in the situation you're referring to) which can happen for any construction of C if you work with fields (that are R algebras) with one marked element.
I don't think this is correct. I bet we can come up with examples of things that are perfectly well defined but are not even uniquely isomorphic to themselves. Isn't the complex plane isomorphic to itself by the identity mapping and also by the mapping of each number to its conjugate? In fact, any nontrivial automorphism will probably be a good example. An isomorphism is enough to call things identical, unique or not.Therodre said:but to satisfy a universal property you already need to be unique up to unique isomorphism
FactChecker said:I don't think this is correct. I bet we can come up with examples of things that are perfectly well defined but are not even uniquely isomorphic to themselves. Isn't the complex plane isomorphic to itself by the identity mapping and also by the mapping of each number to its conjugate? In fact, any nontrivial automorphism will probably be a good example. An isomorphism is enough to call things identical, unique or not.
economicsnerd said:I have to wonder whether this discussion is the right one for clarifying the OP's question.
micromass said:In the case that the OP is still following the thread for all intents and purposes, yes ##\mathbb{R}## is a subset of ##\mathbb{C}##. So unless you're doing some advanced course like analysis or set theory, this is the right answer to your question. And even if you do the advanced course, the answer would still be morally right in my opinion. You can forget the rest of the answers in this thread which will likely be confusing and just take the answer that ##\mathbb{R}\subseteq \mathbb{C}## is true.
Matterwave said:A question of notation here. Why not say ##\mathbb{R}\subset\mathbb{C}## instead of using the symbol ##\subseteq##?
