Are the space and time parts of a standing wave in 3D separable?
7 replies · 861 views
PLAGUE
TL;DR
How can we show that for stationary waves, we can separate the space as time part of a 3D wave equation?
I quote from my book:
In the case of the equation for the one-dimensional stationary wave (Eq. 4-51), in which the magnitude u of the phase velocity was constant and in which solutions were restricted through boundary conditions to a set of privileged constant values for v, we were able to separate the complete displacement function into the product of a space-dependent part and a time-dependent part. It may be shown that when u and v are constant, we may make a similar separation in the equation for displacement of the three-dimen¬ sional stationary wave.
But it doesn't show any proof that for stationary waves, we can separate the space as time part of a 3D wave equation. How can we show that for stationary waves, we can separate the space as time part of a 3D wave equation?
I don't see the distinction between separation of variables,
$$\Psi(\mathbf{r},t)=R(\mathbf{r})T(t)$$
with trigonometric function T and a standing or stationary wave.
PLAGUE said:
TL;DR: How can we show that for stationary waves, we can separate the space as time part of a 3D wave equation?
What is the equation for a 3D stationary wave?
The separation is not a consequence of the wave being stationary.
Rather, stationary modes arise from separable solutions of the 3D wave equation.
Starting from
## \nabla^2 \Psi - \frac{1}{u^2}\frac{\partial^2 \Psi}{\partial t^2}=0 ##,
assume
## \Psi(\mathbf r,t)=X(\mathbf r)T(t) ##.
Substituting and dividing by XT gives
## \frac{\nabla^2 X}{X}
\frac{1}{u^2}\frac{T''}{T}
-k^2 .
Since the left-hand side depends only on space and the right-hand side only on time, both must be equal to a constant.
This yields
## \nabla^2 X + k^2 X = 0 ##,
which is the Helmholtz equation, and
## T'' + \omega^2 T = 0 ##,
with
## \omega = uk ##.
Hence the time dependence is
## T(t)=A\cos(\omega t)+B\sin(\omega t) ##,
and the full solution is
## \Psi(\mathbf r,t)=X(\mathbf r)\cos(\omega t+\phi) ##.
With appropriate boundary conditions, these separable solutions correspond to normal modes (standing waves).
In spherical coordinates the spatial Helmholtz equation can be further separated as
## X(r,\theta,\phi)=R(r)Y_{\ell m}(\theta,\phi) ##,
where
## Y_{\ell m} ##
are the spherical harmonics and the radial equation has solutions given by the spherical Bessel functions
## j_\ell(kr) ##
(and, in general, also ## y_\ell(kr) ##).
Thus, the 1D equation
## X''+k^2X=0 ##
with sine/cosine solutions generalizes in 3D to Helmholtz solutions of the form
## X(r,\theta,\phi)=j_\ell(kr)Y_{\ell m}(\theta,\phi) ##.
The spherical harmonics and Bessel functions are not alternative solutions: they are the angular and radial parts of the same separation of variables.
Of course, this is not the most general 3D standing-wave solution. I used spherical coordinates only to illustrate how the familiar 1D Helmholtz equation
## X''+k^2X=0 ##
generalizes to three dimensions. In spherical geometry, the separated solutions naturally split into an angular part (spherical harmonics) and a radial part (spherical Bessel functions).
Starting from
assume
-k^2 .
This yields
with
## \omega = uk ##.
where
## Y_{\ell m} ##
## j_\ell(kr) ##
## X''+k^2X=0 ##
## X''+k^2X=0 ##
Is this a sufficient condition that "stationary modes arise from separable solutions"?
As far as I understand it, not by itself.
Separation of variables shows that solutions of the form
can exist. However, standing modes are usually obtained when appropriate boundary conditions select a discrete set of spatial eigenfunctions and frequencies.
So I would say that, with suitable boundary conditions, stationary (standing) modes arise from separable solutions of the wave equation.
Which physics textbook are you using? Maybe sharing the name of the textbook so other people can read the chapter, assuming they legally own a copy?
I wonder if the more interesting version of your question is, "are there non-separable solutions to the 3D wave equation?"
Standing waves typically are separable in space and time. However, there does appear to be a case (irregular boundary conditions), when the solution cannot be:
https://www.sciencedirect.com/science/article/abs/pii/S0022460X85800018
