Are wisdom teeth important to get out?
  • Thread starter Thread starter questionboy
    Important Teeth
39 replies · 8K views · last reply
questionboy
I mean ones that arent causin irritation. What do you think?
Biology news on Phys.org
Ask your dentist. Some can not cause any pain...yet...but are situated in a place that is damaging your other molars and will eventually cause a problem. If they are growing in straight and there's room for them in your mouth, then they can be kept.
i still have mine - it depends on the persons! My wifes grew the wrong way and she had to have them out?
I think it depends quite a bit on their size.
All my four were big, so I had to have them out.
Moonbear is correct in my experience. Whether they need to be removed is really a question for a dentist since each person is different. You need to have enough room in your mouth and have them come in somewhat straight.
I did not need to have mine removed since I had room when they came in.
I had to have all mine removed. They didn't even come close to coming in correctly. They're pretty much vestigial and unless you have a giant Neanderthal mouth, they'll probably give you problems at some point in your life.
leroyjenkens said:
... unless you have a giant Neanderthal mouth, they'll probably give you problems at some point in your life.
A brief analysis of the immediately available subjects (8 posters in this thread) results in a 50% retention rate, so...
Another reason to have them taken out, besides impact issues on other molars, is that they can be hard to reach when you are brushing your teeth since they are in the back of your jaw. This can lead to caries. I had all four wisdom teeth taken out (plus four other molars when I was a teen, due to space restraints).
when i was a kid, i had a dentist that wanted to take everyone's out. i think part of the reasoning is that youngsters heal up easily from the surgery, but if you need them taken out later in life, you're more likely to experience complications.
i kept mine, no problems so far.
It was pretty standard practice back then, yes.
JoVieira said:
Does that mean we are the wise ones? lol
Some of us were already too wise, so they had to take out the wisdom teeth to keep us from becoming too much of smart a**es.
(I don't think it worked in my case. :biggrin:)
Caries
I've had one wisdom tooth removed, one is ok, and the other two haven't come through yet, but look as if they'll cause no problems.
It would have been better if I'd had that one removed earlier, since it came through at an awkward angle relative to the next tooth, which led to decay in that tooth because it was difficult to clean it.
My wisdom teeth aren't a problem yet, but my dentist predicts they will be.
50% of people have Neanderthal mouths? :biggrin:
The common explanation I hear is that our wisdom teeth were used for gnawing on roots in our ancestry. I postulate that in some cases, people who are able to keep their wisdom teeth may actually use them more (keeping them from floating by frequently applying pressure to them).
Mine never came in. I guess some just have a genetic defect where they don't get any wisdom teeth.
ooh, they've got to be somewhere! :redface:
they're probably burrowing through to your brain! :biggrin:
I know a woman whose two upper adult canine teeth are moving sideways instead of down …
so they've missed her mouth completely, and you can see that she still has her milk teeth where those adult canines should be!
Apparently her mother had the same thing.​
It could be 100% and it still doesn't contradict what I was saying. Those four people could currently be having problems with them or could have problems later.
Despite that, 8 isn't a very good representation of 6 billion.
I doubt it. It just comes down to there not being enough room for them. If I applied pressure to my bottom left wisdom tooth, it would've probably jammed into my mandibular nerve. The tooth was completely parallel to it, lying right on top of it. There was a chance I could have permanantly lost feeling in the left side of my jaw from having that one taken out.
Honestly, it's probably just the fact that some people have smaller teeth. Not that they're cavemen.
You're evolving. I've also heard of people being born without appendixes.
I still have 4 of them. As I had to move several times from 2004, I had 3 dentists. The Canadian dentist told me to remove them all because they would eventually grow up and this might infect me.
The French one told me not to remove them because according to him they would not grow anymore.
The Argentine one said to get them all removed because they would grow and change the place of all my other teeth. I told her I don't care about it.
I'm still waiting to see who's right. I can say that they grew a little bit from 2004, but I never had any infection or a displaced teeth yet.
You ever see the Looney Tunes episode where some cat puts a mouse in his mouth and the mouse pushes his teeth open like the doors at a western saloon? I know a guy whose two front teeth are starting to do that from his wisdom teeth pushing from the back.
On the contrary, my dentist told me that using a nightguard when I sleep will keep the wisdom teeth down because it keeps constant pressure on them. It's not the only factor, in her opinion, but a significant one. If you're talking about applying enough pressure to jam your tooth into your mandibular nerve, than you're going too far.
Um, no. :eek: Them neva comin' in is just what the dentist and x-rays said years ago.
Oh, you're talking about keeping it from coming in period?
Or keeping them down long enough to straighten up? I don't see why you would have to have teeth pulled when the only problem with them is that they came in wrong. I had a bunch of teeth that came in wrong and I fixed them all with braces.
Naw, they're already in. It was about keeping them from shifting to the point of having to have them removed. Braces are another option. They don't necessarily have to be removed until they cause problems. These are just preventative measures.
If there's no room, then they have to come out.
I'm glad I got mine out, I can easily brush and floss all of my teeth, even the almost-wisdom teeth.
That said, getting them out was one of the worst experiences I've ever had :frown:.
That would be the conclusion based on leroyjenkens' logic, yes. I am providing empirical evidence that it may not a good conclusion.
It doesn't contradict it, no. What it does so is provide evidence that your otherwise-unsupported opinion may be wrong.
They could also be Kings of the Outer Planets, whose teeth are made of diamond. You can't invent conditions then base your conclusions on what ifs.
It is a significantly better representation than is zero - by an order of magnitude or three :approve:.
I was the first one to say that my "evidence" is quite sketchy (n=8). Nonetheless, it's stronger than a mere opinion. It should be trivial to refute my little poll with stronger numbers.
My oldest daughter, Spawn of Evo is a shark. Her adult canine had come in, then to my horror, it fell out. An x-ray of her mouth revealed that she had a third full set of adult teeth coming in. She had to have surgery to cut open the roof of her mouth and extract the third set. We only let the third tooth come into replace the one that had been pushed out.
Now that's evolution in action!
