How Do I Determine the Quantity on a Graph Using Fundamental Theorem?
The discussion focuses on determining upper and lower estimates of total distance using rectangles on a graph, specifically addressing the choice between right and left endpoints when the graph slopes downward. It emphasizes the need for clarity in representing quantities on the diagram, such as the distance between points and the average rate of change. Participants suggest using midpoint rectangles or Simpson's rule for improved accuracy. The conversation also highlights the importance of understanding the relationship between the function and its derivative, as well as how to visually represent these concepts on the graph. Overall, the thread provides insights into applying the Fundamental Theorem of Calculus to estimate quantities effectively.
User Name
http://img521.imageshack.us/img521/4549/bbav9.png
The problem states that it wants the upper and lower estimate of total distance. Therefore, I used rectangles to solve for it. However, let's say I'm working on upper limits. For my initial rectangles, I use the right endpoints, but then it begins to slope downward, so at that point, if I use right endpoints, I am below the graph. Do I continue using right endpoints, or do I switch to left endpoints to have my rectangles stay over the graph?
http://img521.imageshack.us/img521/22/bb2by3.png <--I forgot to put on there that this curve = f(x)
This problem states... for each quantity in questions a-d, copy the diagram and show the quantity on the diagram. Explain what the expression means in terms of the graph. Note that F'(x) = f(x).
For example if the question showed the quantity square root of (b-a)^2 + (f(b)-f(a))^2 then you would explain that this is the distance on PQ and you would draw a line segment PQ on the diagram.
a) f(b)-f(a)
b) f(b)-f(a)/b-a
c) F(b) - F(a)
d) F(b) - F(a)/b-a
I have no idea how to start this.. b and d both seem like slope equations to me, but I don't know the difference.
1st problem, switch. Or better, use midpoint rectangles, or simpsons rule.
2nd part,
a) part a perpendicular line, long enough to cross the segment from B(b) to q. The distance from the point of intersect, and q, is what you want.
b) average change, gradient, gradient of secant connting those 2 points.
c)Area between b and a. shade it in.
d) the average value of the function. Its the height of the rectable with base b to a, with the same area as part c.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
