Area between two curves integral
4 replies · 2K views
Yosty22
Consider the region enclosed by the curves x=2-y^2 and y=-x
Write a single integral that can be used to evaluate the area of the region. Find this area. Your answer should be a fraction reduced to its lowest terms.
NA
First, I graphed them and found the intersection points. The graphs intersect at the points (-2,2) and (1,-1). To write the integral, I decided to integrate with respect to y, I have:
Integral from y=2 to y=-1 of (-y)-(2-y^2)dy
Solving this, I got that the area should be 1.5, however I was told the answer is 4.5. Any ideas where I went wrong?
NA
Remember: an integral is the limit of a sum of a large number of small quantities. When you evaluate a planar area you can either split it up into (a large number of narrow) vertical rectangles (long sides parallel to the y-axis) or horizontal rectangles (long sides parallel to the x-axis). Which method have you attempted to use? Did you do it correctly?
That should work. You'll have to give the details of the integration.
Well you have set this up in a very unusual form (for example, why is your lower limit 2 and your upper limit -1?), but it is a correct setup and as it turns out the integral from y=2 to y=-1 of (-y)-(2-y^2) dy is indeed 4.5. So it looks like you're having trouble with evaluating the integral.
If you need more help, why not show how you tried to evaluate the integral.
Thank you, I realized I made a stupid mistake. - I made a stupid mistake taking the integral.. Thank you guys.
