How Do You Calculate the Area of a Triangle Using the 0.5*b*h Formula?
  • Thread starter Thread starter phospho
    Area Triangle
To calculate the area of a triangle using the formula 0.5*b*h, it is essential to correctly identify the base (b) and the height (h). The height must be the perpendicular distance from the vertex to the base, known as the altitude, rather than a median line from the midpoint of the base. Miscalculations can occur if the wrong measurements are used, leading to discrepancies in the area calculation. Understanding the distinction between medians and altitudes is crucial for accurate area determination. Properly applying the formula will yield the correct area of the triangle.
phospho
Could anyone tell me how they found the area of the triangle?
When I try to use 0.5*b*h I get 10.64483443, not 10.5
They subtracted the areas of the three right triangles outside the given triangle from the area of the rectangle.
How did you calculate b and h for the triangle? I'm guessing you did it wrong.
I found the midpoint of the two bottom verticies of the triangle, then found the length from that midpoint to the top vertex and used that as the height. The length of the two bottom vertices I used as the base.
I see what they done now, thanks, but is how could I have done using the b*h*0.5?
You mean "did".
The line from the midpoint of a side to the opposite vertex is a median. Medians are not generally perpendicular to the side, so its length is not the height of the triangle.
To do it that way you would have to find where the line from the vertex perpendicular to the other side intersects the other side and use that line (called the altitude) for the height.
LCKurtz said:
You mean "did".
apologies for my bad grammar.
thanks for helping.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
