Arguments of Roots of Complex Numbers
The discussion revolves around solving equations involving complex numbers, specifically focusing on the equation z^3 = i and its implications for finding arguments of another complex number w related to the first equation.
  • The original poster attempts to find all possible arguments for w given the relationship w^3 = i(w*)^3, noting a discrepancy between their results and those in the textbook.
  • Some participants question the completeness of the original poster's approach, suggesting that additional solutions may exist by considering the periodic nature of complex arguments.
  • Others suggest rewriting the equation in a different form to explore potential solutions further.
Participants are actively engaging with the problem, exploring different methods to find missing arguments. Some guidance has been offered regarding the nature of complex roots, and there is recognition of the need to consider additional solutions beyond the initial findings.
The original poster mentions that the textbook indicates there should be six solutions, which has led to confusion regarding the completeness of their findings. There is an ongoing exploration of the implications of the 'hence' in the problem statement.
I like number
i) Solve the equation [itex]z^3 = \mathbf{i}[/itex].
(ii) Hence find the possible values for the argument of a complex number w which is such that [itex]w^3 = \mathbf{i}(w*)^3[/itex].
I'm stuck on part ii.
The answer to the equation in part i: e^(1/6 pi i) , e^(5/6pi i ), e^(-1/2pi i )
In the back of the book it has 6 answers, I can only get three of them. If I draw it out on the argand diagram the 3 answers I am missing would be the arguments if you carried the line on through the axis. For example I have arguments 5/12pi , pi/12, -pi/4 and am missing 3/4pi, -11/12pi and -7/12pi.
My method was to cube root both sides:
e^theta i = Z e^ -theta i
Where Z is one of the solutions to part i, by changing Z I can get 3 solutions but am missing the other three.
After seeing in the book there were six solutions I did manage to get them by letting i = e^pi/2 i and setting it equal to e^6theta i, then I just kept adding 2pi to the argument of i until I got all 6 arguments and ended up back at the beginning. However if I didn't have the answers I wouldn't have known to look for the extra three, and this method didn't involve part i) of the question (which I think it is meant to because of the 'hence').
I'd be interested to see how you all approach the problem, and an explanation of what is actually happening.
Thanks
Welcome to PF!
Hi I like number! Welcome to PF! :smile:
(have a pi: π and try using the X2 tag just above the Reply box :wink:)
Hint: write it (w/w*)3 = i :wink:
Thanks for the reply.
Doing that I end up with
e2itheta=3rdrt i
From part i) of the question I have all 3 values for the 3rdrt i , so i set e2itheta= to each of them one at a time , then find theta but this only gives 3 values.
If I was to plot the values I get on an argand diagram mine would be in the first and fourth quadrant, and I'm missing the 3 values from the second and third quadrants.
I hope I'm making sense, and thanks once again for the help.
I like number
I like number said:
e2itheta=3rdrt i
From part i) of the question I have all 3 values for the 3rdrt i …
ok, so you have three values for e2iθ, which is (e)2,
so e is the square-root of that, which has two values, ± of each other. :wink:
:blushing: *doh*!
e= ± eπ/12i
And from this I get the value I had which was π/12 if I take the positive root, if I take the negative root then the argument will be π12 + π = 13π/12 which gives the argument -11π/12 which was one of the missing ones :D If i do this for the others I'll get them :)
Perfect, thank you tiny-tim!
I like number
  • · Replies 22 ·
  • · Replies 18 ·
