ARMA/GARCH estimation with standard errors
1 reply · 2K views
Cyn
I want to estimate the parameters and standard errors of the following ARMA/GARCH model:
##y_t=a+b y_{t−6}+cy_{t−8}+dϵ_{t−1}+ϵ_t##​
##σ^2_t=ω+αϵ^2_{t−1}+βσ^2_{t−1}##​
The code I use is:
Code:
def main():
    x0 = (0.01,0.01,0.01,0.01,0.01, 0.01, 0.01)
    b = minimize(garch_loglike, x0, R_bel, bounds = ((None,None),(None,None),(None,None),(None,None),(0.0001, None), (0.0001, None), (0.0001, None)), options={'disp':True})
    print(b.x)
    value = garch_loglike(b.x, R_bel)
    print("Log likelihood value:", -value)
    a = nd.Hessian(garch_loglike)
    print(a(b.x, R_bel))
def garch_filter(omega, alpha, beta1, eps, R):
    iT = len(R)-8
    sigma_2 = np.zeros(iT)
    for i in range(iT):
        if i==0:
            sigma_2[i] = omega + alpha*eps[i-1]**2 + beta1*np.var(eps)
        else:
            sigma_2[i] = omega + alpha*eps[i-1]**2 + beta1*sigma_2[i-1]
    return sigma_2
def eps1(a, b, c, d, R):
    eps = np.zeros(len(R)-8)
    for t in range(len(R)-8):
        if t ==0:
            eps[t] = R[1]-R[0]
        else:
            eps[t] = R[t+8]-a - b*R[t+2] - c*R[t] -d*eps[t-1]
    return eps
def garch_loglike(vP, R):
    iT = len(R)
    a = vP[0]
    b=vP[1]
    c=vP[2]
    d=vP[3]
    omega = vP[4]
    alpha = vP[5]
    beta1 = vP[6]
    eps = eps1(a,b,c,d,R)
    sigma_2 = garch_filter(omega, alpha, beta1, eps, R)
    logL = -(-len(eps)/2 * np.log(2*math.pi) -0.5 *np.sum(np.log(sigma_2) + eps**2/sigma_2))
    return logL
Here, my data is R_bel. I get parameter estimates, but I do not get the hessian. I thought that with the hessian I could calculate the standard errors. But I get errors such as: RuntimeWarning: overflow encountered in double_scalars. And as output, I get a matrix with nan. How can I solve this problem?
Thank in advance!
[moderator; latex fixed]
The code I use is:
Code:
def main():
    print(b.x)
    iT = len(R)-8
    for i in range(iT):
        if i==0:
        else:
    return sigma_2
        if t ==0:
            eps[t] = R[1]-R[0]
        else:
    return eps
    iT = len(R)
    a = vP[0]
    b=vP[1]
    c=vP[2]
    d=vP[3]
    omega = vP[4]
    alpha = vP[5]
    beta1 = vP[6]
    return logL
Thank in advance!
There's not enough information here for us, or at least me, to be able to help.
How is the minimize function defined?
What is nd? In sum of your following code I see np, which I assume is a numpy class/module.
What does nd.Hessian() return? Presumably it returns a Hessian matrix.
One line of your code is a = nd.Hessian(garch_loglike). In the next line you have print (a(b.x, R_bel)) - this might be the cause of your error, due to two problems:
If a is a two-dimensional matrix, you need to use a pair of brackets - [] -for each index, as in a[2][3].
Second, the indexes in the matrix must be integer values. It's not likely that b.x and R_bel are integers.
