Array of magnets around a sphere
An array of N magnets distributed around a spherical surface can achieve an equilibrium configuration based on their interactions. The discussion highlights the need for precise initial conditions and specific locations of the magnets to derive quantitative results. The concept of uniform distribution among discrete magnets is questioned, as true uniformity is unattainable. References to simulation software and research on sphere-like lattices are provided to aid in understanding the system's behavior. The conversation emphasizes the importance of defining parameters for accurate modeling of the magnet arrangement.
intervoxel
An array of N magnets which can turn freely about their centers in any direction in 3d space is distributed uniformly around a spherical surface (their centers). What is the configuration of equilibrium of the system after some time? (minimum energy)
Do you know of any work showing that?
Thanks.
How much 'uniformly' do you mean? You know, N discrete magnets cannot be in a uniform distribution.
What are the exact locations of the magnets? To get quantitative result, we need more specific information than just that they are on a sphere. I think I can get some numerical solutions once I have an idea about the initial conditions.
It's not possible to make a spherical magnet with one pole inside and the other outside. If you try you won't get the result you might hope for.
Likes 1 person
This post refers to simulation software that can be used to study the Ising model on curved surfaces:
https://www.physicsforums.com/showthread.php?t=409671
This work treats 'sphere-like' lattices, such as a pillow-shaped one and a cube projected onto a sphere:
http://arxiv.org/pdf/hep-lat/9602025.pdf
Is this the kind of work you are looking for?
Likes 1 person
Thanks for your reply, j824h. I was thinking of points belonging to a cubic lattice nearest to a spherical surface of integer radius.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
