Artificial Gravity: Benefits & Uses
6 replies · 3K views
coltsamuel96
Please help me with this problem, at a distance of 40m from the centre of a space station, is a round platform for jogging... compare the weights felt by two persons jogging at 12km/h, when one is jogging in the direction of the rotation of the space station and other in the opposite direction... attempt at the solution, i can get the centrifugal force from the r and v.. ´but after that?thanks in advance
[tex]\vec{F}=m\vec{a}[/tex]
[tex]\vec{a}=\frac{v^2}{r}\hat{r}[/tex]
You'll need to know how fast the station is rotating. If it's not given, then you'll have to write the answer in terms of [tex]\omega[/tex].
the velocity i think can be calculated with v^2/r=g... i think it has to do something with the motion of the person jogging with and against the rotation on the station...
Combining the two equations I listed previously...
[tex]\vec{F}=m\vec{a}=m\frac{v^2}{r}\hat{r}[/tex]
There is your basic equation for centrifugal force.
Now, assume the station is rotating at some angular velocity [tex]\omega[/tex] rad/sec.
You'll need to convert that into a velocity:
[tex]v_s=\omega r[/tex]
Now, if the guy is running in the direction of rotation, then his total speed will be:
[tex]v_{tot}=v+v_s=v+\omega r[/tex]
If he's running against the direction of rotation, then his total speed will be:
[tex]v_{tot}=v-v_s=v-\omega r[/tex]
Now you can plug these two velocities into the first equation:
[tex]\vec{F_+}=m\vec{a_+}=m\frac{\left(v+\omega r\right)^2}{r}\hat{r}[/tex]
[tex]\vec{F_-}=m\vec{a_-}=m\frac{\left(v-\omega r\right)^2}{r}\hat{r}[/tex]
thanks for the help, now i get it...
