Astronomy: Orbit Terminology
41 replies · 5K views
Pixelworks
I am looking for the terms that describe, or rather differentiates the difference between the direction of orbit and the 'anti-orbit' direction.
If my understanding is correct, the terms retrograde and prograde motion both refer to the motion but only in regard to the body being orbited. E.g. the Earth's moon has a retrograde orbit around the Earth, but only because it orbits opposite the direction of the Earth's rotation. If for example the Earth would rotate in the opposite direction the same direction of orbit would be considered prograde. Correct?
If this is the case, what is the determining factor for satellites orbiting a body that does not rotate (i.e. a satellite orbiting the Earth's moon)?
The use-case that I am looking for is to describe the direction a spaceship is taking if it achieves escape velocity to leave a lunar orbit either in the moon's orbit direction or in the anti-orbit direction. If the terms retrograde and prograde are established and applied to the ship's heading (based on the body it is orbiting) then this terminology is still variable and could change depending on the direction of rotation. That is why if I am wondering if there are two other terms that are used specifically to indicate the direction of orbit and the anti-orbit direction.
Thank you for any insights.
Astronomy news on Phys.org
.Scott said:
In this article, NASA refers to the leading part of ISS as the "forward end". So, I would guess the other end would be the "rearward" end.
Aft-end or stern.
Reply
Moon revolves and rotates in the same direction as the Earth's rotation.
It just happens that the Earth rotates faster than the Moon revolves.
Reply
I didn't address the term "retrograde" as it pertains to celestial motion.
The strictly scientific definition is provided in this wiki article.
However, the original astronomical meaning (from the 14th century) and still the more common meaning, is used to describe an apparent westward motion of a planet.
Reply
DaveC426913 said:
Aft-end or stern.
I wouldn't use "stern" for this. "Stern" describes something that functions as a stern - not just its position. If you put a boat into orbit, its stern could be either the forward end or the aft end.
Reply
Sorry. Yes, you are absolutely correct... that example was a Brain-fart on my side. :) In a moment of 'unconcentration', I forgot that a moon's zero rotation relative to the host planet (aka tidal-locked) does not mean that the body doesn't rotate.
But the question remains the same, how is the prograde or retrograde direction determined if the body in question is not rotating?
I think maybe I explained my question incorrectly or perhaps the terms that I am looking for simply do not exist in the form that I am looking for. Let me try a different formulation...
First off, I do not mean the front or back of a spaceship itself, but rather the terms for the ship's heading when it leaves orbit. Regardless whether a ship is orbiting a body in a prograde or retrograde direction, it can leave orbit either in the direction of the planet's orbit or against the planet's orbit (i.e. leaving orbit in the backwards direction opposite the direction that the planet is traveling).
Of the eight planets in our Sol system, all except two (Venus & Uranus) rotate counterclockwise. That means if we retain the usage of prograde and retrograde for this definition of direction, then leaving the Earth's orbit in a prograde direction would be the retrograde direction for the same direction when leaving a Venus orbit (as seen from above the Sol system (zenith) looking down.)
Which is why I am wondering if there is a term for leaving a celestial body in its direction of its orbit or the anti-orbit direction. Where the term is based on the celestial body's orbit direction and not on its rotation direction. Similar to a solar system, the galaxy is also spinning. At least at this level, I have seen references that traveling in the direction that the galaxy is turning is called 'spinward' and the opposite direction aptly classified as 'anti-spinward'.
Aside from that, there is also a polar orbits (and orbit from north to south, or vice-versa) that I would assume are classified as neither prograde nor retrograde. I do not know if it has ever been done or even if there is a practical purpose for doing so, but I would assume that this would be called either the zenith or nadir direction, depending on if the ship leaves the planet in a northward or southward direction.
You probably want the term 'posigrade', but you'd likely need to add some qualifiers to make it clear which orbit you mean. The opposite is also retrograde.
Reply
Bandersnatch said:
posigrade
Had to look it up to be sure, but YES, that is the term that fits. It is a shame that retrograde is used for both cases though, so yes, that direction would need clarification when used.
Thank you!
I realize this is not what you are asking but there are some pretty strong constraints on orbits and leaving them.
Assuming it lifted off from Earth in the first place, it will almost surely have a prograde orbit, since that takes advantage of the 1000mph boost of Earth's orbit. To then leave orbit retrograde, it will have to kill its 18,000mph prograde velocity and reverse it.
Likewise, leaving the galaxy anti-spinward would require killing all of its prograde 230km/s velocity and reversing it for a total delta-v of ~460km/s.
(And if you have that much fuel available to make that produce kind of delta-v then you essentially don't need to worry about orbits at all, you can just go in any direction you desire.)
So with realistic fuel and delta-v constraints, the only time it's practical or functional is if you have arrive at the planet in a retrograde orbit (say, Venus). Then you might as well leave in the same direction.
Reply
As I read it, the OP doesn't want to reverse the orbit, just to identify a direction. As in e.g. a spaceship making a burn along or against the instantaneous orbital velocity vector when performing a Hohmann transfer. It would burn posigrade when raising the orbit, or retrograde to lower it.
but then again you may well know that, and are just musing.
Reply
Well, he sure seems to say so, if I read it corectly:
Reply
For ISS and similar orbiting targets that a chaser might want to approach and rendezvous with, there is also a fairly well-established terminology using R-bar, V-bar and H-bar to designate, relative to the target, the direction towards Earth, the forward velocity direction (perpendicular to R-bar) and angular momentum axis (perpendicular to R- and V-bar). Due to the quirkiness of (relative) orbital dynamics these directions are important for approach and departure procedures.
Reply
Thank you Dave, this maybe not what I was asking, not reversing orbit, but leaving orbit in one or another direction... As per my understanding, achieving a prograde or retrograde orbit is possible by taking course towards the right side or left side of a celestial body. Nevertheless, you still touched on very interesting points.
Correct. Unless I am mistaken, if I wanted to leave an orbit in either a posigrade direction or a retrograde direction it would for example simply be a matter of achieving orbital escape velocity on the left side of my prograde (Earth) orbit to continue parallel to the planets orbit (posigrade trajectory) or leave the prograde orbit on the right side to travel away from the planet in the opposite direction of the planet's orbit (retrograde trajectory).
Thank you for the terms Filip, I am pretty sure 'posigrade' was exactly what I was looking for, but I will check those out, there are often very fine differences between the usage/meaning of these types of discussions.
[Edit]: I just read up on your link above, If I understand their usage they are mainly used for 'close-quarter' maneuvering (i.e. docking procedures) or course alignment of two ships... and yes, I will definitely be needing these terms as well. Thank you for the contribution.
I found out that the term 'antigrade' can also be used to mean 'retrograde' when speaking in terms of the opposite of posigrade.
However the author also admitted that antigrade is largely uncommon and that although the usage of retrograde causes confusion when speaking in contexts using both orbital mechanics as well as vectoring, retrograde remains by far the more common term for both meanings.
That is correct.
Reply
Indeed. Using posigrade term has the benefit of being separate from prograde which in classical orbital mechanics very much is tied in with the orbital inclination ##i## such that orbit is equatorial, prograde, polar or retrograde depending on whether ##i = 0##, ##0 < i < 90^{\circ}##, ##i = 90^{\circ}##, or ##i > 90^{\circ}##.
As has been noted already, in some contexts authors seems to assume orbits are prograde so that orbit raising is a prograde maneuver while orbit lowering is a retrograde maneuver. I am not sure what those authors then call these maneuvers in case of retrograde (i.e. ##i > 90^{\circ}##) orbits. For maneuvers it is perhaps better to simply refer to the main effect, like orbit raising/lowering maneuver, inclination change maneuver and eccentricity change maneuver (which may keep the period constant).
Reply
Exactly. That is what caused me to begin my search for a term that I did not know to describe a relational motion that I needed. Prograde was the only term that I knew at the time and it works great for satellites that are in a long term orbit or when the perspective is primarily on the planet itself, but as soon as you have spaceships that have more volatile trajectories or if the orbital path (not the rotation) is focus on a stellar scale, prograde can become confusing.
Bandersnatch said:
'posigrade'
At any rate, thank you Bandersnatch for the tip in the right direction and thank you everyone else for contributing as well as the other many good ideas. :)
I am a visual type and luckily (or maybe because of) I like to draw things out.
Here is the result of my understanding so far (not to scale):
Summary:
Definition of Rotational Direction
Prograde1: is the direction of a celestial body's rotation and synonym to 'clockwise' as seen from the northern (zenith) pole looking down.​
Retrograde1: is the direction of a celestial body's rotation and synonym to 'counter-clockwise' as seen from the northern (zenith) pole looking down.​
Definition of Orbital Relationships
Prograde2: is a satellite's 'forward' direction of travel based on the direction of rotation of the celetial body the satellite is orbiting.​
Retrograde2: is the 'backwards' direction opposite of Prograde.​
Definition of Orbital Paths
Posigrade: is the 'forward' direction of travel based on the orbit path.​
Retrograde3: (synonym but uncommonly known as 'Antigrade') is the 'backwards' direction of travel but opposite of Posigrade.​
Do note, you have the lunar orbit going the wrong way. The only way in which it is retrograde, is in the context of its apparent motion on the sky as seen from Earth, w/r to the background stars. The orbit itself is prograde.
Also, can you provide a reference using pro/retrograde to describe the rotation? I don't think I've ever seen that before - not to imply that my ignorance bears much weight here.
Reply
Bandersnatch said:
Do note, you have the lunar orbit going the wrong way. [...] The orbit itself is prograde.
Correct, I wanted to change 'lunar' to 'satellite', but forgot. The idea was to show the difference... unfortunately Venus does not have any moons. I will correct that so as not to confuse anyone.
I will have to check where I found that, but I know it was used in connection to the Sun's rotation (probably because it is not orbiting anything that we from the Earth would readily reference: i.e. the Milky Way core).
Take a look at Uranus and its moons. Some of the outer ones are in retrograde orbits.
I did not bring Uranus into the discussion, because Uranus is a more complicated example due to its rotation at a 98° angle... meaning it is rolling like a ball along its orbit path. Because Uranus is tilted ~98 degrees, its equator (and consequently its rings and major moons) sits vertically rather than horizontally, orbiting top-to-bottom relative to the solar system's plane.
But yes that is exactly, the type of environment where it makes sense to differentiate between posigrade and prograde. :)
PS. I changed my picture above to represent the various terms... I tried to make an animation out of it, but the file size restrictions here forced me to lower the quality by a large margin.
Regarding your Prograde1 I would say it is relative to the rotation of the primary body it orbits (and not relative to its own north pole, unless you define the north pole as the same general direction as the north pole of its primary).
See for instance the Wikipedia page for retrograde motion:
Prograde satellites of Uranus orbit in the direction Uranus rotates, which is retrograde to the Sun.
Uranus relative to the Sun perhaps, but not so much its own major inner and outer moons.
(I see only now that I falsely reversed the clockwise/counter-clockwise directions above, unfortunately I can no longer edit my post to correct this... perhaps an admin can help me out?)
Your comment coincides with Prograde2, my listing of Prograde1 was a reference that I found referring to the sun's rotation (which aside from the galactic arm "orbiting" around the galaxy's center has no primary body to be the determining factor), but I assume this same principle would also apply to rogue planets, etc.
[Correct directions as opposed to my post above]
If my interpretation of the usage was correct, this form of prograde1/retrograde1 is only used if no parent is present to base the direction of rotation on. In which case the definition of a Prograde rotation defaults to counter-clockwise (being the general norm) and it is a Retrograde rotation if the "parent-less" body is rotating clockwise.
And yes, the direction of rotation and pretty much everything else is based on the planetary plane zenith perspective, which for most systems is the north pole of the primary star looking downwards.
Unlike the Earth, stars have unstable magnetic fields. Our sun swaps polarities every eleven years. I assume every star is similar.
Good point, I would assume the same. but the magnetic fields do not define the star's rotation (aside from a braking effect) or the perceived zenith/nadir poles of a star.
For the zenith/nadir poles the planetary plane is the usual point of reference... however for systems that are rotating/orbiting clockwise, it is a bit of a chicken or egg discussion. I can only guess that a clockwise system (retrograde1 per my interpretation above) is considered as orbiting 'backwards' if it was naturally formed in a clockwise direction and the poles are the therefore defined in the same north/south direction as counter-clockwise systems (as seen from the galactic plane).
If on the other hand, the system is classified as spinning upside-down from a galactic-center perspective (i.e. the system flipped at some point during its evolution), the zenith/nadir poles are respectively reversed from counter-clockwise systems.
Probably a mute point as I do not think we are able to determine if a flip occurred or if a system was just born that way.
