Undergrad Why Do Astrophysicists Use νLν in Accretion Disk Emission Studies?
The discussion centers on the use of νLν (where ν represents frequency and Lν denotes luminosity at that frequency) in the emission spectrum of accretion disks, particularly in Active Galactic Nuclei (AGNs). Participants explain that νLν is preferred for plotting luminosity to reduce graph size and enhance visibility, especially when using logarithmic scales. The product νLν allows for easier interpretation of the spectral luminosity, which is measured in units of W/Hz. Additionally, the typical double hump structure observed in AGN spectra further supports the convention of using νLν in these studies.
  • Understanding of spectral luminosity and its units (W/Hz)
  • Familiarity with Active Galactic Nuclei (AGNs) and their emission characteristics
  • Knowledge of logarithmic plotting techniques in astrophysics
  • Basic concepts of accretion disks and their relation to black holes
  • Research the role of νLν in astrophysical spectra and its implications for energy measurements
  • Study the logarithmic plotting methods used in astrophysics, particularly for AGN emissions
  • Explore the double hump structure of AGN spectra and its significance in emission mechanics
  • Read "Astrophysics in a Nutshell" by Dan Maoz for a comprehensive overview of spectral analysis
Astrophysics students, researchers studying Active Galactic Nuclei, and professionals analyzing emission spectra in astrophysical contexts will benefit from this discussion.
Astroiaco
Why in Astrophysics it is used νLν (where ν is the frequency and Lν is the luminosity at that frequency) in the emission spectrum of an accretion disk?
Astronomy news on Phys.org
Frequency is used to identify nuclei, while luminosity will tell you how much.
Ok, but why often in the plot of luminosity (where there are ν in abscissa and ν*Lν in ordinate) there is the product between ν and Lν and not only Lν? I don't know if i explained myself better.
Accretion disk are of different scales, depending on the mass of the black hole. But guessing from your profile pic and the similarity of the field I assume you are talking about the supermassive black hole accreting galactic matter; more precisely Active Galactic Nuclei(AGNs).
Here's why I think it is so: to reduce the graph size!
There's something you missed, sometimes the graph is plotted logarithmically, otherwise in powers of 10. This is because the Spectrum is expected to account for the variations across the whole electromagnetic range, and hence the graph would be too big if plotted in normal units.
Spectral-energy-distributions-SED-of-the-blazar-PKS-2155-304-during-its-2006-highly.png
A similar reasoning goes for plotting the product νLν. In log units this is easier to see. Notice that log(νLν)=logν+logLν. Now look at the above graph, a simple subtraction will tell you that the y-axis of the graph scales from -24 to -35 if only logLν is plotted.
Another reason might be by convention. Usually AGNs have a typical double hump(the shapes vary for different sources) structure when plotted as a product. In field they usually fit the different emission mechanics to this double hump structure; not that you can't do this for just luminosity, it's just what they do.
PS: Why I think this can't be from concrete theoretical calculation? Well, it doesn't matter if you plot luminosity or the product of luminosity and frequency, since the only quantity with nontrivial variations is the luminosity. Besides there are options in plotting program to plot ν2Lν.
  • Spectral-energy-distributions-SED-of-the-blazar-PKS-2155-304-during-its-2006-highly.png
Likes Astroiaco
Could you pls provide a reference source? I suspect that ##L_{\nu}## would be a spectral luminosity, i.e. luminosity per an unit frequency interval, measured in units ##(W/Hz)##. By multiplying this value and a specific frequency interval ##\nu##, you should get the total luminosity in Watts over this specific interval.
Likes Astroiaco
I'm studying the AGNs for my undergraduate thesis, so i have many reference sources, but for example you can find this type of writing on: Dan Maoz "Astrophysics in a Nutshell".
Yes, ##L_{\nu}## is measured in units ##(W/Hz)##.
phoenix95 said:
Accretion disk are of different scales, depending on the mass of the black hole. But guessing from your profile pic and the similarity of the field I assume you are talking about the supermassive black hole accreting galactic matter; more precisely Active Galactic Nuclei(AGNs).Here's why I think it is so: to reduce the graph size!
Thank you very much!
Ah good, I think I found quite a nice explanation in Carroll&Ostlies: "An Introduction to Modern Astrophysics", two snapshots below. If I got it right, when you construct graph like this, the area under the curve of an interval will be proportional to the amount of energy received in that interval (i.e. "equal areas under the graph correspond to equal amounts of energy").
Likes Astroiaco
  • · Replies 18 ·
