Ship Disappearance Distance and Asymptotic Geometry
  • Thread starter Thread starter member 428835
    Geometry
An observer at sea level can determine the distance a ship disappears from view based on its height, represented as ε, which is much smaller than the Earth's radius. The key to solving this problem lies in understanding the geometry of the situation, particularly using the Pythagorean theorem to relate the observer, the ship's base, and the ship's height. The distance d between the observer and the ship's base can be approximated as d = r√(2ε) when considering small angles. Different approaches to the problem highlight the importance of low-order approximations and the curvature of the Earth. Ultimately, the conclusion is that the distance a ship disappears is approximately √(2ε).
member 428835
An observer from sea level watches a ship sail away from shore. If the ships height is ##\epsilon \ll 1## after scaling with the radius of the earth, show that the distance the ship disappears will be about ##\sqrt{2\epsilon}##.
Nothing comes to mind.
Not quite sure where to start here. I'm thinking of a sort of right triangle made with the observer, the ship base, and the ship height, but I just don't know the distance between the ship and observer.
I imagine the square root appears from the pythagorean theorem (the three points being the observer, ship base and ship height) though I'm unsure. Anyone give me a nudge in the right direction?
You have to take into account the curvature of the earth.
So the distance ##d## between the observer and the ship's base would be ##d=r\theta##, ##r## being the Earth's radius, but I don't know what ##\theta## is.
Start by making a sketch of the situation, so you can see what is going on. Then you will be better able to translate that into equations and formulas.
Likes epenguin and Chestermiller
Yea, I did this right away, but all I know is the Earth's radius and the ship height. It just feels open ended.
Actually, the three relevant points are the observer, the top of the ship and the center of the earth. If w is the angle between the observer and the ship (as measured from the center of the earth) you can get the observer-ship distance in terms of the Earth's radius and the angle w.
I think I did this in Post 3. In this case the distance would be ##rw##. I could find the distance from the observer and the top of the ship too if you think this is relevant?
If ##\epsilon## is much smaller than the Earth's radius, do you think there would be any noticeable difference between the distance to the bottom of the ship vs. the top of the ship? Of course, the answer is YES if you want exact results, but you being asked about "lowest-order" approximate answers. What is your answer in that case?
The walking distance along the Earth would still be ##d = rw##. The distance from one point to another would be ##\sqrt{2r^2(1-\cos w)}##. However, the distance from the viewer to the top of the boat is $$\sqrt{r^2+(r+h)^2-2 r(r+h)\cos w}=\sqrt{2r^2+2rh+h^2-2 r^2\cos w-rh\cos w}\\
= r\sqrt{2+2\epsilon+\epsilon^2-2\cos w - \epsilon\cos w}.$$
If ##w \approx 0## (not very far along the total circumference) then ##\cos w \approx 1 \implies d = r\sqrt{2\epsilon}## (ignoring ##\epsilon^2##).
Yes, but you are supposed to be working with a low-order approximation for small ##w##. What then?
Likes member 428835
Shoot I think I was editing and posted the response you were looking for? See post 9.
I did this much differently. I had: $$\cos{\theta}=\cos{(s/r)}=\frac{r}{h+r}$$
where s is the arc length along the great circle. Using the small angle approximation for cosine, I get:
$$\cos{\theta}\approx 1-\frac{\theta^2}{2}\approx 1-\frac{1}{2}\left(\frac{s}{r}\right)^2$$Also, assuming h<<r, $$\frac{r}{h+r}\approx1-\frac{h}{r}$$
OK now.
Alternatively...
We have a right triangle with sides ##r##, ##r+\epsilon##, and the distance ##d##.
We can neglect any differences between the arc length and the side of the triangle corresponding to the distance.
Now apply Pythagoras:
$$d=\sqrt{(r+\epsilon)^2 - r^2}=...$$
Likes Chestermiller
Wow lots of different ways people are solving this! I'm going to mark it solved. Thanks for everyone's perspective!
  • · Replies 16 ·
  • · Replies 17 ·
